Pages: Prev 1 2 3 4 5 6 [7]   Go Down
Author Topic: Command Technologies 2500 amp aka Dedicated RF aka AN Wireless  (Read 9453 times)
WS8RM
« Reply #90 on: February 09, 2012, 03:34:01 AM »
Now, man to man, I assure you that any 'mess' was inherited by me ......Meanwhile, I'm working as best I can with those who do have     "legitimate product issues" HuhHuhHuhHuh
Dan
[/quote]
I was thinking that you did not "INHERIT" you bought! (the Command line) -- Just what WOULD BE a legitimate product issue that you WOULD be interested in?
WS8RM
KK3AN
« Reply #91 on: February 09, 2012, 09:17:50 AM »
Wayne, you're twisting words around again & trying to turn this into a game.
Dan Simmonds
K6AER
« Reply #92 on: February 10, 2012, 12:02:38 PM »
Dan,
When you have time call me. 303 246-3518
Mike - K6AER
ZENKI
« Reply #93 on: February 11, 2012, 12:24:35 AM »
Hopefully these new Command amplifiers will have filament voltage adjustment on them.
Voltages taps on the primaries of the transformers for line voltages as great  250 volts would also be of benefit.  These days none of the providers care what the line voltage rises too,
If these amps are going to be good as  the designer says they gonna be, I will buy one only because it uses clean Eimac Triodes and not Russian Junk tubes.
KK3AN
« Reply #94 on: February 11, 2012, 10:23:22 AM »
Coincidentally - yes. I'm in the middle of sourcing a filament transformer (perhaps a toroidal) that will have taps from 100v to 250v, and our intent is to auto-sense the primary AC.
I know this problem all too well. At my rural QTH, I've personally measured my own mains voltage anywhere from 214 up to 248. There's no rhyme or reason for this incredible variance that I can identify.
Dan Simmonds
ZENKI
« Reply #95 on: February 11, 2012, 11:04:12 PM »
Great news, your amps will be the first amateur radio amplifiers that has this feature.
Dan Simmonds
NM3G
« Reply #96 on: February 12, 2012, 06:50:29 AM »
Dan,
Just a suggestion ... rather than using an EI Iron-core transformer, why not use a switching power supply with current and voltage regulation, as well as current monitoring. With multiple tubes (or with tubes with dual filaments), knowing the current is down from nominal certainly enables quick troubleshooting. With regard to voltage monitoring, measuring the voltage at the tube socket pins with a pair of sense wires ensures I^2 losses are canceled, and the filaments remain at a constant, regulated voltage regardless of the line input voltage (well ... for the nitpickers, as long as the input voltage is within the range of modern switchers). The power supply will be lighter as well.
Note ... this is the arrangement I've seen on all sorts of different tube-based MRI amplifiers, including the new ones that have just come out in the last 5 years.
Rick
NM3G
KK3AN
« Reply #97 on: February 12, 2012, 06:33:59 PM »
Rick,
Honestly, Don and I feel that's an excellent idea. We are going to investigate the switching supply more tomorrow. We've already located one today that could work with all amps (1, 2 and 3 tubes).
73, Dan
Pages: Prev 1 2 3 4 5 6 [7]   Go Up
