Yes you
will have issues! Better check the SWR on
all the bands, but I figure the garage door has destroyed it. Don't burn up your transmitter!
That is why I
don't spend $100 for a mobile antenna. I use solid stainless steel whips and mount them so they clear overhead objects or can be bent over to garage. The closest I get to a coil antenna is an open air coil that is part of the main rod on my VHF/UHF antenna.
By the way, you probably would have gotten more responses if you had listed your question under the "
Mobile Ham" category.
