Hi Allen,
So there is no way I would have 2600 volts with 700ma if only one tube was working?
Well, if you have a good single tube you can actually hammer it that hard. It won't last long, but the 8873-5 series has a lot of reserve emission.
One last thing I did do. I drive it with a brand new Kenwood TS-590S. I noticed when I put the am in standby the wattmeter in the MLA-2500 would read my output from the radio. The radio (SWR 1:1) wit 100 watss reading on the radio, the MLA-2500 read 50 watts. So maybe I am 50% off on the reading on the amp. LOL
That sounds like the power meter is 50% off, assuming SWR is low on your antenna.
Be really careful with that amplifier. The 8875 tubes are unobtainium now, and they are VERY easily damaged from excessive grid current. The grids can be popped in as little as 30 seconds!
If your 2500 does not have the mod to read grid current, you should add it. Also it is a good idea to add a grid trip circuit to disconnect if the grid current gets too high, and to lower the filament voltage so it is in the MIDDLE of the range at your median line voltage. Dentron ran the filaments a bit too hot.
73 Tom
