Hello all:
I got a question that needs to be clarified;
I am working on a Bogen amp and i was measuring the voltages at the power supply as per the schematic diagram of which i include a link to it:
http://www.emailtom.org/images/bogen-chb20a.jpgIt says there should be 400 volts at the top of c18, then 375 volts after the 2.7 kohm 3 watt resistor (Top of c19b), and then 250 volts after the 22kohm 1 watt resistor (top of c19c).
I can see 450 volts in my voltmeter on the first point. measuring from chassis to that point. Then i go to the next point and see no voltage. Same happens with the third point.
If i go in between c18 and c19a, i see a voltage of 250 volts.
I am testing the voltages with no tubes in the sockets.
I am also making sure that i am not poking around with my two hands and making sure i am discharging the caps all the time.
The amp seems to be dead when i tried it out the first time. I can see that the filaments light up alright but there is absolutely no sound whatsoever.
Please help!!!!!!
