It makes a HUGE difference whether you have AC hum on your transmitted signal or you are just listening to vibration from your power supply as the load is applied. I wouldn't start replacing any components until you really determine that it is affecting your transmitted signal. Component changes aren't likely to fix a mechanical problem unless you happen to accidentally tighten something during the replacement process
