Author Topic: Difference between OCXO and TCXO?  (Read 663 times)
W9KDX
« on: February 14, 2012, 08:04:40 PM »
I am clueless here.  What is the difference, in performance that the user would experience, between a +-0.05 ppm OCXO oven instead of the TCXO oven?  Apparently, the Yaesu FT DX5000MP has the OCXO, while the other version have the TCXO.
Much thanks.
Sam
W9KDX
KQ6EA
« Reply #1 on: February 14, 2012, 08:26:12 PM »
An "OCXO" is an "Oven Controlled Crystal Oscillator" while a "TCXO" is a "Temperature Compensated Crystal Oscillator".
An OCXO *should* have better stability, especially over wide temperature ranges (cold shack in the winter?) while a TCXO is probably good enough for most of us mere mortals.
+/- 0.05ppm from the OCXO +/-would equate to about 1.5Hz at 30MHz, while the +/-0.5ppm from the TCXO would be 15Hz at 30MHz.
Some rigs offer an "Ext Ref In" which would allow you to use something like a GPS disciplined oscillator, or a Rubidium standard for even greater accuracy.
Does it matter?
Probably not at HF frequencies, but if the rig has a "Transverter Output" jack, the the increased accuracy and stability *would* matter if you're using the radio with a microwave transverter.
At 10GHz, the .05ppm oscillator could result in a final frequency error of 500Hz, while the .5ppm oscillator could be off by 5kiloHertz, a significant amount.
Jim
HB9PJT
« Reply #2 on: February 15, 2012, 05:43:09 AM »
Allmost all HF rigs are connected to a transverter for ordinary radio signal TX and RX paths. But not as a frequency normal. So the transverter has its own local oscillator which determinants the frequency accuracy of the system mainly. In that case a rig without a TCXO or OCXO is more than adequate.
73, Peter - HB99PJT
Does it matter?
Jim
W9KDX
« Reply #3 on: February 15, 2012, 12:51:24 PM »
I love the line " for most of us mere mortals".  As I am well into the mere mortal class, I got my answer.
Thanks, what a great resource.
Sam
W9KDX
