Author Topic: Hammarlund clock adjuster shaft extension needed  (Read 738 times)
K7WXK
« on: February 15, 2012, 12:02:20 PM »
Could use some help finding the tapped adjuster shaft estension for the Hammarlund Telechron clock.  Any and all ideas will be appreciated.  Posted a want ad in the classifieds as well.
Marc
mtniebs@gmail.com
K7WXK
« Reply #1 on: February 16, 2012, 06:35:39 AM »
Well, I was able to make one myself.  Thanks anyway.
Marc
KD0ACY
« Reply #2 on: February 20, 2012, 06:19:27 PM »
How did you do it?
Mike
K7WXK
« Reply #3 on: March 08, 2012, 09:13:00 AM »
I went to ACE Hardware and got some 1/4" aluminum stock.  Put it in the vise and drilled a hole smaller than the threaded adjuster on the clock.  Sawed the stock off to the proper length.  Did sort of a self tapping of the adjuster rod into the hole of the stock.  Works great, but recommend turning clockwise to prevent accidently unscrewing the shaft.  It's a stinker to get it back together inside the cabinet.  I had to slide the cabinet off the radio in order to work on the shaft/adjuster mating.  Then you have to fish the shaft back through the hole in the back of the cabinet.
Hope this helps.
Marc
