Author Topic: Are doppler shift direction finders effective?  (Read 6760 times)
LB5KE
« on: February 16, 2012, 06:48:56 PM »
Or just a vaste of money?
« Reply #1 on: February 16, 2012, 09:50:38 PM »
It depends what you expect them to do.
First, I presume you mean a true doppler system, which uses an array of antennas that is
electrically rotated.  Some people use the term for the two-antenna switched antenna arrays,
but they really don't use the doppler shift.  A better term for the two-antenna variants is
TDOA (Time Difference of Arrival).
Dopper DF units aren't as sensitive as a beam with a good receiver because the commutation
noise can mask weaker signals.  They don't give you as much information, either:  you still
get just one point on the display if you have a reflection, while a beam will show two peaks
to alert you that there is a reflection.  For fast mobile hunting in relative open terrain they
can work well.  In hilly terrain, or in a city area where buildings are more than two stories,
they tend to have more problems with reflections.  For very long range work - where you have
to take bearings from hilltops to triangulate the signal, a good beam or Long Baseline
Interferometer can give a more accurate bearing.
It's another tool to have available.  In the flat plains of the central US, or in the Los Angeles
basin, they are quite popular.  I think I have a board around here somewhere, but have never
seen that one would be very useful in among the local hills.
And if your unit has a 100Hz switching frequency and the hider modulates the signal with
a 101 Hz tone, you'll just sit there and watch the indicator turn circles around the display.
because conditions are suitable.
« Reply #2 on: February 17, 2012, 11:17:59 AM »
If you are talking about a $25K+ professional unit then yes, they are pretty effective. If you are talking about one of the "add on" units that plug into your HT then probably not so much.
It also depends on your operational limitations. For example, if you are driving around in a vehicle and the target is also moving then its pretty difficult to use a directional antenna. If on the other hand, you are walking and the target is fixed then a hand-held directional antenna can work quite well.
Also, many of the mobile automatic units have moved away from doppler shift to TDOA.
N6JSX
« Reply #3 on: February 18, 2012, 08:25:54 AM »
If I knew T-Hunters were using Dopplers I'd put my hidden T antenna horizontal negating the effectiveness of heir Doppler use as vehicle Doppler RX antennas are vertical.   Tongue
Doppler mobile/vehicle use requires a strong signal >S6 for direction and relegated to forward/aft-port/starboard of the vehicle while the vehicle is moving to allow visual averaging of reflections. Dopplers are of little to no use on weak signals.  Huh
I did use a Doppler, for a short time when going after repeater problems when speed is of the essence in finding these problems. Since I was the driver/hunter I found I could not study the Doppler while driving safely in Southern CA traffic.   Shocked
I found it much easier to become proficient at using my 2m 3element special T hunt Quad. One of the keys to my success was using my design/built external noise/S meter. I placed it directly in front of me on the dash but the real key was incorporating an audible tone speaker that parroted the meter response, stronger the signal the higher the audible tone. The other key was my two step built in attenuation built around controlling the B+ of the radio's 1st RF mixer; one step removed the B+ to the base & the other step 10K variable pot to control the collector B+. This was needed to keep the external meter displays centered and not pegging/saturating the meter/circuit.  Grin
Sometimes I could psych myself into thinking I was close to the Fox/T ; to keep me in perspective I placed a HT on my dash removing the rubber-duckie (helical dummy load), set the HT to just barely squelch out full volume. If this HT started to bark at me I knew I was within 1/4mi or closer and usually I was already switching in first step of radio attenuation.  Cry
I've been thinking about trying a Doppler again, but the issue I always found was the cumbersome mediocre antenna system was less than adequate. For my next Doppler I'm going to make each of the four antennas 1/2wave dipole (like Adcock Sys). Now the trick will be how high off the vehicle does it need to be to negate vehicle metal/field affects?   Cool
The techno fun of T hunting!   Wink
K1ZJH
« Reply #4 on: March 14, 2012, 08:00:30 AM »
In my foolish youth, when I was a repeater operator and trustee, I'd use a doppler to track down
clowns who were jamming our local repeaters. More than once I'd be out at midnight, chasing drunks
and other social misfits with two meter rigs.
I found the doppler to be absolutely essential. It always brought me right to the driveway of
the miscreant. The problem with the cheaper units is the use of digital swtching to simulate a
rotating array, that causes a lot of receiver noise and reciprical (sp?) mixing problems. And you
have to be moving to average out the reflections to see the true heading. You can usually
"hear" the reflections in the speaker as it garbles the tone.
Fortunately these days I've moved on to a small repeater with close knit group, and the
lids have given up jamming since the large audiences are no longer on FM.
Pete
