Author Topic: Two rigs on one antenna through a coax switch  (Read 2905 times)
ND9B
« on: April 17, 2012, 06:31:07 AM »
I have two high powered rigs that I want to use with one antenna. Would it be safe to use a Daiwa CO-201 coax switch for this purpose? This particular switch shorts the unselected port to ground, but the actual isolation is not specified. I just want to make sure transmitting on one rig won't nuke the other.
Bobby Dipole
« Reply #1 on: April 17, 2012, 07:31:04 AM »
You shouldn't have a problem with this setup.  The offline radio antenna terminals are shorted to ground which prevents RF from getting into the radio.  I would also have the offline radio shut down as well to prevent RF from getting into the radio by any other means.
ND9B
« Reply #2 on: April 17, 2012, 07:54:02 AM »
Bobby Dipole
I just realized that I could measure the switche's isolation with my RF generator and the S-meter on my rig. I cranked the generator up on 20M (the highest freq band I use) for a reading of 60 over 9, then flipped the coax switch. The S-meter fell all the way to the end of it's range. The isolation must be at least 100db if the meter is right! I see no problem now.
Bobby Dipole ND9B
« Reply #3 on: April 17, 2012, 09:14:18 AM »
Bobby Dipole
Been doing this for many many years with up to 3 rigs with a few other brand switches over years and never had any problem with my Kenwoods.
M5AEO
« Reply #4 on: April 17, 2012, 03:12:43 PM »
I asked exactly the same question a few months ago!
I run two transceivers and a receiver in this same way via a 3-way coax switch from Diamond.  The company specifies 60dB of separation between the 3 ports and I have experienced no problems or interaction between the rigs.  I am only running up to 100 watts however, so the higher RF power that is generally used in the USA should be taken into consideration.
Jonathan, M5AEO, London UK.
« Reply #5 on: April 17, 2012, 04:38:12 PM »
Not really a problem unless you have more than one amp in line too and I switch rigs BEFORE amp.
