Author Topic: PC Headsets  (Read 1650 times)
9H1FQ
« on: April 21, 2012, 12:07:04 AM »
I have a Lexma X255 headset, works excellent on a PC. I want to fit it onmy transciever, but I am puzzled with the mic connection. It has the usual 3.5mm jack, with a tip, ring & sleeve. The connection to the PC soundcard input is indicating that both the 4.5 volts supply and the audio output are coming from the tip. When tried to feed it this way, with a 10uf dc blocking capacitor, it did not work. Anyone can help please. Thanks
An unknown gem of the Mediterranean sea is the Island of Malta. blessed with warm sun , all year round.
In just one day, you can see places which will make you travel in history from the Prehistoric temples throu the middle ages, the Knights of Malta, all the way to world war two. All the major civ
N4NYY
« Reply #1 on: April 21, 2012, 06:11:18 AM »
If that headset has a electret mic, then that is shadow voltage for the preamp in the element, and is needed for the mic to work.
G8JNJ
« Reply #2 on: April 21, 2012, 07:12:33 AM »
Hi,
See this document for some ideas.
http://g8jnj.webs.com/Boom%20headset.pdf
Regards,
Martin - G8JNJ
ww.g8jnj.webs.com
