Author Topic: 2M radio set off CO detector  (Read 4770 times)
N4NYY
« on: July 08, 2012, 02:06:17 PM »
One of my club members gave me a nice programmed GE Phoenix commercial 2M rig to get me on the air. Needless to say, the damn thing works great. However, it set off one of my 2 CO detectors. I have a Diamond ground plane antenna in the attic (ranch house) so the antenna is only one level up.
The one that went off is an older one, which is only about 10 feet away from the newer one. At this point, I just unplugged it but the easy fix would be to get a newer detector. I just do want to get one and then that one it set off.
Any other ideas?
« Reply #1 on: July 08, 2012, 02:23:52 PM »
Switch the more sensitive detector with the detector farthest from the antenna.... Or, move your 2 Meter GP outdoors WHERE IT BELONGS.
Does the GE have only one power setting? Like 25 Watts? Personally, I never liked running more than 5-10 Watts with an indoor antenna 'cuz it just seems like a bad idea.
N4NYY
« Reply #2 on: July 08, 2012, 03:07:08 PM »
Quote from: AC5UP link=topic=84055.msg607164#msg607164 kdate=1341782632
Does the GE have only one power setting? Like 25 Watts? Personally, Io never liked running more than 5-10 Watts with an indoor antenna 'cuz it just seems like a bad idea.
I do not think I can hit the repeater on low power. Too much foliage and too low. All the settings are on the inside.
W5FYI
« Reply #3 on: July 08, 2012, 03:23:03 PM »
   Don't you know you're suppose to call "CQ," and not "CO?"
N4NYY
« Reply #4 on: July 08, 2012, 03:46:05 PM »
Ha! Not a bad idea.
« Reply #5 on: July 08, 2012, 03:58:27 PM »
Vinnie is in New Jersey so that would make him a CO2............. Although I think of him more like a CH4.
<zing!>
N4CR
« Reply #6 on: July 08, 2012, 07:49:12 PM »
...Damned if I can understand what the big deal is about the Higgs boson particle. I had a box of them I bought
over 20 years ago that was taking up space in the garage and last spring when I was doing some cleaning...
Just throwing them out doesn't really get rid of them due to the first law of thermodynamics.
You'll need some anti-matter to really do the trick.
73 de N4CR, Phil
N4NYY
« Reply #7 on: July 08, 2012, 08:02:54 PM »
I think you replied to the wrong thread! LOL
KB3HG
« Reply #8 on: July 09, 2012, 08:49:33 AM »
Is it a battery powered detector or ac hardwired?  Hard wired typically are connected to others. I used to use magnets to test  smoke detectors. In another life I tested thousands of them. HT's never had a problem. it should of had some immunity from rf. When in doubt, throw it out. I certified too many buildings to take a chance on questionable device.  The only other question would be how dusty is it?
Tom
N4CR
« Reply #9 on: July 09, 2012, 09:12:25 AM »
Look in his signature block.
73 de N4CR, Phil
KD0REQ
« Reply #10 on: July 09, 2012, 10:36:09 AM »
the detectors confirm it... hamming is a gas.
N4NYY
« Reply #11 on: July 09, 2012, 06:58:30 PM »
OMG. I am going blind.
« Reply #12 on: July 10, 2012, 06:29:17 PM »
Get battery powered detectors or move the antenna farther away from them.
Unless you have some specific antenna restriction, put the antenna up above the roof and higher: Not only will it work a lot better, but this problem will go away.
