Author Topic: kenwood radio  (Read 2533 times)
G7UKR
« on: July 21, 2012, 10:58:08 AM »
i have a kenwood ts50 radio,my question is.when i switch my radio on the background on the display keeps fading then it will go bright. does anyone have an idea what could be causing it.and how to fix it.     malcolm g7ukr
K9YLI
« Reply #1 on: July 22, 2012, 08:13:44 AM »
first you need the schemaitrc.  likley down load-able form several sites.
measure the   light source voltage after it  gets normal brightness.. write it down.
then measure the voltage at the  light source as you  power it up.
if it varies, chase it thru the schematic, untill you find the component that fails to supply  steady voltage.
replace said component.
this will take some   power up/ cool down  cycles  to chase...
KA5IPF
« Reply #2 on: July 22, 2012, 08:21:17 AM »
C1 in the display unit has leaked and damaged the traces/thru-holes on the board. Remove the cap, clean up the leakage, and repair the damage. Then install another cap.
Clif
G7UKR
« Reply #3 on: July 23, 2012, 10:47:48 AM »
thank you ka5ipf clif and k9yli,thank you for your info have printed your answers out and will keep them and will check them out when i get time.thank you again malcolm g7ukr
« Last Edit: July 23, 2012, 10:51:53 AM by G7UKR » Logged
KE4DRN
« Reply #4 on: July 23, 2012, 08:18:22 PM »
hi Malcolm,
Manuals are in pdf no cost at
http://www.radiomanual.info/KENWOOD.html
Join other TS-50 and TS-60 fans here
http://groups.yahoo.com/group/Kenwood_TS50/
I have photos of the pc board and the location of
the electrolytic capacitor that causes the problem.
Also the location of the plated through hole that
I cleaned and used magnet wire to repair the connection.
73 james
« Last Edit: July 23, 2012, 08:20:13 PM by KE4DRN » Logged
W5DQ
« Reply #5 on: July 24, 2012, 10:54:02 AM »
Step 1) Remove the power cord from TS-50. Set TS-50 aside.
Step 2) Replace the TS-50 with a brand new Yaesu FTDX9000.
Step 3) Send the TS-50 to me Smiley I'll dispose of it and take care of associated disposal fees.
That should take care of the problem Smiley
Just kidding of course. Sounds like one of the replies may have it all lined out for you.
Good Luck.
W5DQ
Gene W5DQ
Ridgecrest, CA - DM15dp
www.radioroom.org
