Author Topic: DM780 diplay lissue  (Read 10300 times)
KR4VT
« on: August 05, 2012, 07:31:11 AM »
I am trying to set up remote digital using DM780 and LogMeIn from my iPad. The connection seems to work fine but the display on the iPad does not show the complete waterfall, only the top of the waterfall window. The numerical frequency scale is visible but nothing below it.
I have adjusted the resolution settings but no help, I figure it has to be a setting that I'm missing.....any ideas on what to try next?
Robert
NK5G
« Reply #1 on: August 13, 2012, 07:48:09 AM »
Hi Robert
I run remote using both the iPhone and iPad. Although I have not experienced this problem, maybe I can point you in a direction that will help.
If you can see the desired video output on your pc then it should also be Good on LogMeIn. Make sure all your display settings are good here first.
Second, make sure it all looks good remoting from another pc before you try the iPad.
Although you said the resolution was fine, you might want to play with different settings on the iPad. I use 1280x768 on both the pad and the phone. Make your pc resolution match this.
Check the network speed, mine is auto, but you may need something slower.
Hope some of that helps. Again, if the video is good remoting from another pc, then the issue is on the iPad side.
David, NK5G
