Author Topic: Nissan Murano Installs?  (Read 3610 times)
NF9K
« on: September 14, 2012, 11:48:54 PM »
Does anyone have a mobile setup in a late model Murano?  I'm getting ready to put an ID-880H in our 2009 and would love to see some examples to compare to what I've cooked up.  I'd like to eventually add HF as well.
KB4QAA
« Reply #1 on: September 15, 2012, 12:37:10 PM »
1.  check out Alan's website   http://www.k0bg.com/
2.  Just do it.
W9MMS
« Reply #2 on: September 15, 2012, 03:24:55 PM »
2.  Just do it.
Gotta agree
JUST DO IT!
(((73))) Milverton
WA1KWA
« Reply #3 on: September 18, 2012, 04:29:09 PM »
I have a 2004 Murano. I have an IC-208H, which looks similar to your rig. I mounted the main body of the transciever in the center console. I removed the center console insert, and it just allows you to put the insert back in & then close the lid. Ran the cables under the center console; mounting the female RJ-40 mic connector inside the drivers side of the most forward storage space in the console, the one with the rubber mat, about 5 inches square. Mounted an inexpensive MFJ external speaker on the drivers outside of the console, using Velcro so the XYL can eaisly remove it & put in the normal center console storage bin (above the remoted rig) when she has the car. The control head I mount on the dash near the Sat Nav display. I did not use the Icom remote mount, but again with Velcro. I can ditch it out of sight in a hurry, since I can't disconnect it rapidly without tools like the Kenwood dual bander in my truck.
Pardon the pun, I know your's is not a 2004, but I hope this helps, your mileave may vary. Different rig, different model year, so.......(Had to say it)
73,  Colin
WA1KWA
NF9K
« Reply #4 on: September 18, 2012, 06:35:42 PM »
Thanks, Colin.  I'm hopefully going to get my install finished in the next few days. I'll post photos when I'm done.
