Author Topic: SWR  (Read 24151 times)
W5DXP
« Reply #15 on: January 14, 2013, 01:26:52 PM »
OK - that's one! Any more Wink
Some of the early SWR meters, e.g. Heathkit, had a small slotted line that directly sampled the forward and reflected fields. I had a pickup loop, taped to my parallel feedline, with two attached flashlight bulbs that glowed with forward power and reflected power. Does that count?Smiley
73, Cecil, w5dxp.com
WB4SPT
« Reply #16 on: January 14, 2013, 02:22:27 PM »
Sorry, no.  That's a directional coupler.  My slotted line device demanded that the operator physically move a RF probe back and forth inside a essentially a coax with a slot cut lengthwise.  So, you would move the equivalent of a quarter wave to get the max and min RF voltage on the center conductor.  THen do the division of Vmax / Vmin = SWR.  Can you imaging adjusting your antenna tuner doing all that?  You had it easy, even with the old HK.  Grin
I forgot something.  You can measure the wavelength with the slotted line also. Probably won't get you the accuracy of a HK GR64 even.
« Last Edit: January 14, 2013, 03:09:01 PM by WB4SPT » Logged
