Author Topic: ic-2720  (Read 1187 times)
W8NIC
« on: January 16, 2013, 06:01:25 PM »
does anyone know how to set crossband on this radio? info will be greatly appreciated.
thanks.
larry w8nic
W6EM
« Reply #1 on: January 16, 2013, 07:15:13 PM »
Larry:
You can download a manual here:  http://mods.dk/manual.php?brand=icom
Lee
W6EM
K9YLI
« Reply #2 on: January 21, 2013, 02:01:02 PM »
I have it  printed out some where.  its not in the regular operator manual.
I down loaded lit from some where.
Hold two buttons on power up  , but i forget which.   I have never bothered to try it.
KQ6Q
« Reply #3 on: January 22, 2013, 08:18:58 PM »
I have the same radio mobile, still use it, but gave up on the crossband repeat. It did work at first, but I melted the solder connections on the finals using it. When it came back from repair, the crossband repeat function didn't work anymore. probably for the best!
K9YLI
« Reply #4 on: January 23, 2013, 08:04:40 AM »
by the  by..  you do have to  run the  output at  medium or low power as its  on,  100% of the time               if no further  info  i will hunt thru the  stackand find the  correct answer  to
how to do it..
