Author Topic: DVT-B sticks as a spectrum analyzer  (Read 10348 times)
K9AQ
« on: January 18, 2013, 08:12:31 AM »
I am using a DVT-B with an upconverter as an SDR panadapter.  I see a real potential for using this also as a building block for a low-cost spectrum analyzer.  Has anyone done any experimentation with this?
Don
K9AQ
KA4POL
« Reply #1 on: January 18, 2013, 09:48:45 PM »
With the emphasis on low-cost you don't have to do much. It mainly depends upon the software you are using. I have been doing this with my QS1R so why should the stick not work.
ZENKI
« Reply #2 on: January 19, 2013, 01:13:53 AM »
How much on screen dynamic range can you get?
What will be the minimum resolution bandwidth be?
SM5BSZ has already been using LINRAD with  these DVT_B tuners. Linrad has a nice mode called TX Test mode which is excellent for checking transmitters for splatter etc.
You might check SM5BSZ's web page he has lot of data there.
Don
K9AQ
KN0CK
« Reply #3 on: January 19, 2013, 05:24:36 AM »
Don / ZENKI,
You have a great idea, but unfortunately the DVB-T USB receivers only exhibit a dynamic range in the area of 45dB which makes it fine for casual tuning as a panoramic display, but not for making signal measurements.  The reason for the marginal dynamic range is that the original intent of the DVB-T sticks was for picking up strong digital TV and radio signals and it worked fine for that, along with that the 'stick' has 8-bit tuning making it limited by design, too.  At 45dB dynamic range, it just doesn't make a very good spectrum analyzer for looking at spurs and other RF phenomena.
But you can still use it as a companion to your setup for viewing your I.F. off ANY radio (provided you upconvert it to what the 'stick' tunes to) and that you use the appropriate software that gives you the best panoramic display properties.  And as you're probably already aware, the DVB-T stick is a pretty nice - again casual listening - SW and Ham Band HF/VHF/UHF receiver provided you use an upconverter for HF and leave the upconverter off for VHF/UHF coverage.
73 de Marty, KN0CK
« Last Edit: January 19, 2013, 05:31:26 AM by KN0CK » Logged
KA4POL
« Reply #4 on: January 19, 2013, 10:29:11 AM »
a) 90 dB
b) maximum resolution 25 kHz across screen
I think you mean max and not min.
ZENKI
« Reply #5 on: January 25, 2013, 04:11:54 AM »
All interesting information guys. It would still be useful as a general purpose bandscope for older radios. For the price it just show the potential of the design. The Funcube dongle
is another ground breaking product.
Who knows someone might package the device as a PSK IMD monitor along with a Android or Iphone app. It certainly has potential
WV4I
« Reply #6 on: January 25, 2013, 05:55:05 AM »
Following the Jan 2013 QST article, I acquired a DVB-T from Ebay for about $30 shipped. I got it working on a Win 7 32 bit OS, using SDR# software. I don't know exact dynamic range etc., but have mainly tried it on FM BCB, AM Aircraft, and 2M FM. Compared to receivers designed for those bands, it has a fraction of the apparent sensitivity, S/N ratio, etc.. For the price however, can't beat it as an entry level SDR receiver. And as some have mentioned, as a simple pan adapter and/or looking at relatively strong signals, the price/value ratio again can't be beat.
You will need a good antenna at least attic, if not outside, to hear very much, for the CCR or apartment bound. A discone comes to mind.
Also running Softrock and SDR-IQ on HF. I think that by time getting up converters etc., to use DVB-T for HF, you'd be better off getting one of the Softrocks or some other SDR in $100 range. The SDR-IQ easily outperforms the Softrock, but it's also $500 new. Only money, hi.
« Last Edit: January 25, 2013, 05:57:35 AM by WV4I » Logged
