Author Topic: multi-band vertical  (Read 2616 times)
KF7ZCH
« on: March 25, 2013, 07:48:30 PM »
I am planning on making a coax trap vertical for the 10, 15, 20, 30, 40 m bands.  The antenna will be about 7 feet from a two story house.  I am planning on having two radials per band giving a total of ten.  However, where I am installing them would only permit me to have them in basically the same orientation.  I am putting it a part of the yard which is surround by walls and concrete, thus I can only put the radials in about a 5 feet by 100 feet section.  Will the antenna still work, and if so how well?
K1WJ
« Reply #1 on: March 26, 2013, 09:00:08 AM »
How high will antenna be?
Ground mounted allows you to put as many radials & length that will fit.
If elevated 2 feet or higher at base of antenna, one 1/4w radial per band will work, even if all all on the same side, fan out a few inches from each other.
73 K1WJDavid
KQ6Q
« Reply #2 on: March 26, 2013, 02:12:56 PM »
the antenna setup you described will work, but it will be directional, toward the radials extended from the antenna. don't expect much in other directions.
KF7ZCH
« Reply #3 on: March 26, 2013, 02:15:09 PM »
Thank you for the tips and suggestions.  They are much appreciated
K1WJ
« Reply #4 on: March 27, 2013, 09:30:50 AM »
I have a 20m vertical with one elevated 20m 1/4w radial 4ft off the ground.
The radial is to the east side, make just as many contacts to the west.
73 K1WJ David
M6GOM
« Reply #5 on: March 27, 2013, 10:06:52 AM »
The difference will be around 6dB or 1 S point in the quadrants where no radials are. It should still hear plenty in that direction, just not as good as it could've done i.e a signal which would've been S7 had there been radials will be around S5-6.
