Author Topic: MIC AUDIO USING A MIXER  (Read 5376 times)
KD7SXQ
« on: April 04, 2013, 05:51:41 PM »
DEAR FORUM:  I AM TRYING TO IMPROVE MY TRANSMIT AUDIO BY HOOKING UP A BEHRINGER DX 626 MIXER TO MY FT-897 HF RIG, I HAVE NO EXPERIENCE IN DOING THIS, BUT HAVE WIRED MANY MICROPHONES TO WORK WITH GOOD REPORTS. I AM USING ONLY ONE MICROPHONE AND ONE RADIO. WOULD APPRECIATE ANY HELP ON THIS SMALL PROJECT.  THANKS VERY MUCH FOR READING.  LYLE KD7SXQ
AC2EU
« Reply #1 on: April 04, 2013, 08:09:36 PM »
How is the mixer going to enhance your audio?
Besides the output of a mixer will be a bit "hot" for a mike input. Yaesu uses dynamic mikes.
VA7CPC
« Reply #2 on: April 04, 2013, 08:18:04 PM »
Posts are easier to read WHEN YOU STOP SHOUTING.
The DX626 seems to have a mic input preamp (XLR connector), and a MAIN OUTPUT.
Plug the mic into the XLR socket (there may be a switch to change from MIC to LINE input).    Adjust the preamp gain so you don't overload the preamp.
Run the MAIN OUTPUT to the FT-897 "DATA IN" rear-panel connector.  That wire should have RFI protection -- ferrite chokes might be enough.  A 1:1 transformer would be even better.
Connect a PTT switch from the DATA IN "PTT" pin to the GND pin.
Put the rig into "DATA" mode (see the instructions for "Packet operation" in the manual).
Adjust the MAIN gain control so that you get reasonable AGC action on voice peaks when you transmit.
That should get you started.
.           charles
PS -- there's a page on Bob Heil's website that talks about connecting a Behringer mixer to a ham rig.  I don't think it's very good (he assumes you're using the MIC input to the rig), but for reference:
http://heilsound.com/amateur/tips/behringer.php
PPS -- if you have a PSK31 rig-to-computer interface (not something with its own soundcard), you can use that for voice.
KD7SXQ
« Reply #3 on: April 05, 2013, 02:18:13 AM »
WA7CPC:   THANK YOU SO MUCH FOR THE INFORMATION. THIS IS JUST WHAT I NEEDED TO MAKE THIS ALL WORK. I NEED TO BUILD A BREAKOUT CABLE/BOX AND I WILL HAVE IT WORKING IN NO TIME AT ALL. THANKS AGAIN.   KD7SXQ  Cool
K0OD
« Reply #4 on: April 05, 2013, 06:20:37 AM »
"How is the mixer going to enhance your audio?"
ENHANCING AUDIO? GENERALLY IT'S ALL ABOUT ADDING MORE SHINY KNOBS.
(did the OP even read the replies?)
AC2EU
« Reply #5 on: April 05, 2013, 06:49:21 AM »
That appears to be the case...  Grin  Roll Eyes
« Reply #6 on: April 05, 2013, 09:58:04 AM »
Darn.  That explains why it didn't help me...mine had dull, satin-finish knobs.
Do you know where I can get a knob upgrade kit?
« Reply #7 on: April 05, 2013, 11:10:11 AM »
Take a picture and photoshop it. It'll look great on your QSL card  Cheesy
K0OD
« Reply #8 on: April 05, 2013, 11:12:08 AM »
SHINY knob upgrade kit for Kenwood hybrids made (and now discontinued)  by K4EAA.
http://k4eaa.com/knob4.jpg
He also makes a kit to convert old Kenwood hybrids to all-upper case panel lettering.
http://k4eaa.com/knob8.jpg
Convert that old Kenwood to a KENWOOD
WN2C
« Reply #9 on: April 05, 2013, 11:19:52 AM »
No it won't help and neither does SHOUTING !!  Turn off the CAPS lock!
AC2EU
« Reply #10 on: April 05, 2013, 05:53:22 PM »
Maybe he's using a mill?  Grin
WA3SKN
« Reply #11 on: April 08, 2013, 03:47:55 PM »
The FT897 uses a 600 ohm microphone and The front jack is probably designed for about -60 dBm input.  The back jacks in the radio are designed around line levels, or about 0 dBm, and will be a closer match for your mixer.  But don't forget about supervision... the PTT that switches between transmit and receive.  Many in their haste forget to include it in their planning!
Good luck with the project!
73s.
-Mike.
