Author Topic: Yaesu FC-902 : Meters stopped working  (Read 4253 times)
W9GB
« on: April 06, 2013, 07:14:57 AM »
The meters on my Yaesu FC-902 antenna tuner have stopped functioning,
but the antenna tuner functions normally. I used an external Power/SWR meter to perform my matching.
This tuner has a small number of parts, and I noticed in the schematic diagram
that the meters use a couple of small PC boards with a few components.
Any thoughts on what to look at? I see a couple of small signal diodes on one of the boards. Thanks
The CM Coupler in the Yaesu FC-902 Antenna Tuner uses 2 diodes, D101 and D102.
1SS16, Schottky barrier diode, Yaesu part number: G2090038
http://www.foxtango.kc9foz.com/FT101ZD-901-902/fc902.pdf
Yaesu used this same diode in other Yaesu equipment, such as the mixer unit of the
FT-7 and FT-9xx transceivers.
DO NOT subtitute a generic silicon diode in this CM coupler unit.
A Silicon diode has a voltage drop between 0.6–1.7 volts.
A Schottky diode has a voltage drop between approximately 0.15–0.45 volts.
A Germanium diode has a voltage drop of approximately 0.30 volts.
The lower voltage drop of the Schottky provides higher switching speed and efficiency.
Couplers for amateur radio equipment (Drake, Heath, etc) that used meters (SWR, etc.) often used germanium diodes (1N34A, 1N60, 1N270).
http://www.angelfire.com/electronic2/index1/1N270.pdf
Substitution of these germanium diodes with modern Schottky diodes is common.
I use the Central Semiconductor CDSH270, Schottky replacement for 1N270.
This part is readily available from Mouser.
http://www.centralsemi.com/PDFs/products/CDSH270.PDF
Small signal Schottky diodes, like the 1N5711, 1N6263, 1SS106, 1SS108 or the BAT41–43, 45–49
can also be substituted for the 1SS16 in your FC-902
w9gb
N4ATS
« Reply #1 on: April 07, 2013, 05:00:41 AM »
Very easy fix , replace them with these , this is what I use...
http://www.angelfire.com/electronic2/index1/In34a.html
I replace them quite frequent in meters
W9GB
« Reply #2 on: April 07, 2013, 06:03:03 AM »
The original 1SS16 Schottky barrier diode is 5 Volts, 30 mA rated to 900 MHz,
with a forward breakdown voltage of 0.50 Volts.
The 1N34A and 1N60 are common Germanium diodes, for lower voltage circuits.
Voltage and current ratings for Germanium Diodes still found today.
1N34A : 65 Volts, 50 mA
1N60 : 45 Volts, 50 mA
1N270 : 100 Volts, 40 mA
1N277 : 110 Volts, 75 mA
Schottky Barrier Diode, BAT-46
Lower forward break down voltage than a Germanium diode at less than 10 mA.
Forward breakdown voltage is 0.25 , while Germanium diodes are 0.35 volt.
« Last Edit: April 07, 2013, 06:20:16 AM by W9GB » Logged
