Author Topic: Yaesu FT-890 AT 60 meter mod  (Read 8517 times)
WT4E
« on: April 13, 2013, 01:41:56 PM »
Does any one know if you do the 60 meter mod you lose your tuner function? I did mod and turned off rig and held proc,  agc, ipo,  att, per instructions hit and turned back on a #2 came up I turned knob to on and hit proc to save change and 60 meter mod works but tuner stopped working. Now with that being said that procedure takes you into a sub-menu that is not talked about in manual and I cant find anything on it, I fugre I must have turned something off primarily the tuner but not sure when or how. Does any body have these settings or know what they all do, thanks 73es Dave
N4ATS
« Reply #1 on: April 13, 2013, 04:13:22 PM »
The radio was designed to do DC to 30 MHz , you will not lose anything nor will the radio change ANY sensitivity.  The tuner will work flawlessly as well even after the modification. Most , if not all HF radios are designed to do DC to 30 MHz as different countries use different frequency bands...
