Author Topic: What is the OD of Buddipole mast?  (Read 2617 times)
W0ALE
« on: May 04, 2013, 09:00:54 AM »
I'm wondering if anyone knows (or could measure) the outside diameter of the Buddipole mast.  I'm thinking about buying the tripod to use with some military surplus aluminum masts I bought which are 1.785".  Not sure if they will fit in the Buddipole tripod or not.
73!
W0ALE
« Reply #1 on: May 10, 2013, 02:06:34 PM »
Does anyone have one they can measure?  I sent an email off to Buddipole a week ago but haven't heard anything.  I want to get my mast up.
VE3WMB
« Reply #2 on: May 10, 2013, 08:32:26 PM »
I just measured it, it is only 1 and 1/8 inches OD at the base so it looks like you are out of
luck.
Cheers
Michael VE3WMB
P.S. What is the inside diameter of the surplus military mast. Could you put a 1 1/8 in pipe into the
Buddipole mast and then slide your aluminum mast over the top ?
73!
W0ALE
« Reply #3 on: May 10, 2013, 09:29:54 PM »
ID measures 1.57"
