Author Topic: Amp for an Ft 450D  (Read 5080 times)
W4JJA
« on: May 08, 2013, 05:11:19 PM »
What would be a good amplifier for my Ft 450D?
John
N4ATS
« Reply #1 on: May 08, 2013, 05:19:03 PM »
Yaesu FL-7000 , the BEST SS amp ever made and still available.
N4CR
« Reply #2 on: May 08, 2013, 06:29:32 PM »
An Ameritron AL-800 would be an excellent choice.
73 de N4CR, Phil
Never believe an atom. They make up everything.
VE3PP
« Reply #3 on: May 09, 2013, 01:18:36 PM »
A vague question as we do not know how much power you want to be able to put out.
Any amp will work with the FT-450. All of the newer amps simply require a keying cable from radio to amp. Older amps like the SB-200 require a relay between the rig and amp as the amp has a higher voltage on the keying relay. Unless it has been modified with the Harbach soft key.
I have an Ameritron AL-80A in line with a FT-950. Single 3-500Z tube. With 60 watts drive the amp has an output of about 700 watts on 80 meters (which along with 40 Meters is about the only two bands I use the amp on)
It will cruise along at 700 watts all day long, never get warm. The tube will last a long time if you do not abuse it. Nice desk top amp. You can buy used ones, or look for a newer AL-80A. For the amount you spend, even on a new one that amp is a good value.
N4CR
« Reply #4 on: May 09, 2013, 08:53:15 PM »
Bet I made him look...
73 de N4CR, Phil
N4ATS
« Reply #5 on: May 10, 2013, 08:16:46 AM »
I would use an FL-7000 , auto band tracking , solid state , built in auto tuner, no-tune. They cruise at 700 watts...
PA1ZP
« Reply #6 on: May 13, 2013, 09:54:23 AM »
Hi to you all
Any amp will do.
I had a FT920 and on AL572B no problems.
I had a FT450 and used it with a AL572B no problem.
I have a FT857D no problem on AL572B
Now have TS590 no problem on 572B
But if You are planning for something like Alpha 9500 or Acom 2000 , I would go for AL82B and keep the change to upgrade your FT450D for a bit better rig.
Though I had a FT450 for 3 yrs I didn't like the RX of the rig much on both CW as on SSB.
But there is no reason why you could not make Legal Limit with the FT450D
I am rather fond of the single 3-500 AL80B now and that would work OK with the FT450D to.
Good luck with your search for your amp.
73 Jos
