Author Topic: Icom IC-765  (Read 1720 times)
N8HO
« on: August 23, 2013, 12:30:27 PM »
My IC-765 has no audio from the speaker or when using headphones.  Also, when I move the transmit/receive switch from receive to transmit nothing happens.  The rig is presently connected to a 40 meter dipole that works well with my other rigs.  I have the audio gain control set fully clockwise, RF gain control fully clockwise and squelch control fully counter clockwise.  The rig changes bands, the display seems to be working properly the automatic antenna tuner motor turns when changing bands.  The two fuses inside the case are good.  I have not used this rig for about a year and accidentally powered it up with the transmit/receive switch in the transmit position.  Any suggestions will be appreciated.
« Last Edit: August 23, 2013, 12:37:29 PM by N8HO » Logged
