Author Topic: IC-765 on low band receive antenna?  (Read 4445 times)
W0XX
« on: September 01, 2013, 10:35:25 AM »
ANyone ever use the IC-765 on low bands with a receive antenna?  What hook up did you use as this radio does not have a selector for regular antenna to receive antenna?
« Reply #1 on: September 01, 2013, 11:00:59 AM »
According to page 12 of the IC-765 instruction manual, connectors are provided for breaking the receive connection between the antenna tuner and the receiver circuit--you could put a protection circuit and an receive antenna switch between those connectors. You want to look at section 4-7
http://www.aytechnologies.com/TechData/RIP-1.pdf
Here is a commercial protection circuit you can buy.  A receive antenna can actually pick up a watt or more of signal from a nearby transmitting antenna--more than enough to burn out an unprotected receiver.
Zack Lau W1VT
W0XX
« Reply #2 on: September 01, 2013, 06:16:45 PM »
Hi Zack
Yeah, I saw that but no mention as to a methodology of using it.  I suspect one would have to use something like the DX Engineering RTR-1 so you can switch the receive antenna in or out, otherwise, as it stands, it would be in line all the time and that isn't desireable.
W0BTU
« Reply #3 on: September 01, 2013, 07:24:08 PM »
When I only used one separate RX antenna, I just used a mini SPDT toggle switch. Later, I used 3 of those. Now I use a rotary switch that controls relays. The photo and schematic is on http://www.w0btu.com/Beverage_antennas.html
If you can drill and solder, you can make one. It's simple.
W0XX
« Reply #4 on: September 02, 2013, 03:34:27 AM »
Yes, that would work to swtich in a rcv antenna, but risky if you are concerned about rf getting back into the rcv antenna to the radio during transmit.  Have to isolate the two completely.
