Author Topic: Collins KWM-380-- repair / advice / tips?.  (Read 37096 times)
ZS5WC
« on: September 06, 2013, 07:43:18 AM »
 Smiley Hi All,
I have become the proud owner of the SECOND Kwm-380 in South Africa-(perhaps the whole of Africa as well..), and am about the start the repair process.
YES, I am aware of the CCA, but am asking the question here--so here goes:
The rig has been stored most of it's life, and when the previous owner tried to switch it on-apparently the tantalum caps that supply the synth. board got fried.
It is a bit of a concern--cap's don't just blow willy nilly, but could have happened due to the long storage.
I HOPE one of the regulator pass devices aren't short..
What other things should I look for-perhaps you have restored one of these yourself?.
73 de William
ZS5WC / ZS4L
W9GB
« Reply #1 on: September 06, 2013, 08:10:47 AM »
Tantalum capacitors, of this era, DID have a habit of launching like a rocket from a PC board.
Dangerous, without safety glasses, when this happens on electronics work bench !
That can be a potential cause.  Do you know how to test?
There are a handful of top KWM-380 experts in Cedar Rapids, IA area (Collins HQ, radio was mfg. nearby in Anamosa, IA).
These qualified Collins employees (some in support and design) SHOULD be sought for advice -- this radio is NOT for Novice techs, due to scarcity of some parts and  low number of these radios and military HF-380 produced.
Jim Maccani, WØHUP is a very good Collins tech on the KWM-380.
Jim Maccani - WØHUP
4140 Elkhorn Drive N.E.
Cedar Rapids, IA 52411
USA
jimscs@mchsi.com
Phone: +1-319-393-0094
Hal Guretzky - K6DPZ
Land-Air Communications
95-15 108 Street
Richmond Hill, NY 11419
USA
Phone: +1-718-847-3090
FAX: +1-718-849-8279
landaircom@aol.com
« Last Edit: September 06, 2013, 08:19:55 AM by W9GB » Logged
KG6YV
« Reply #2 on: September 06, 2013, 01:38:07 PM »
Oh yeah, I second the opinion/observation that tantalum caps are known for "uncaused" explosion.
I have a Tektronix scope in which a tantalum in the power supply went "boom" luckily while in operation with the covers on.... Tantalum capacitors are bombs when they fail, and they are so
tiny for their explosive power....
W9GB
« Reply #3 on: September 06, 2013, 02:07:55 PM »
William -
As I remember, only 2,000 of these radios were produced from 1979-1983.
I lived in that area, when the production lines were ending in 1983.
There were ~ 20 factory modifications for the KWM-380/HF-380 during this period.
http://www.wb4hfn.com/COLLINS/Documents/Brochures/KWM380/Brochure-KWM380.htm
WARNING - The October 1979 Owners Manual - INCLUDING the PDF that is floating around on the web has a MAJOR MISPRINT.  The REAR Power connector wiring shown in 1979 manual is wrong and WILL cause damage to your transceiver.
The correct owners manual is the SECOND EDITION - dated January 1, 1981
and a scanned PDF is available (January 1 , 1981 - Owners Manual), here:
http://www.w2xc.com/pdf/Collins%20KWM-380%20owner's%20manual%202nd%20edition%201%20January%201981%20(sm).pdf
Bob Grinnell at Surplus Sales of Nebraska (USA) acquired many of the remaining/spares parts,
when the KWM-380/HF-380 production lines were shut down in late 1980s.
http://www.surplussales.com/Collins/Collins.html
W2XC personal notes on the KWM-380
http://www.w2xc.com/KWM-380_Notes.htm
In May 1980, Rockwell/Collins produced a training document (PDF, 225 pages):
You will require the KWM-380 Owner's and Service Manuals to go along with this training course.
Self Study Training Course on the Collins KWM-380 Transceiver
http://collinsradio.org/archives/manuals/KWM380_Self_Study_.pdf
« Last Edit: September 06, 2013, 02:26:13 PM by W9GB » Logged
ZS5WC
« Reply #4 on: September 09, 2013, 12:40:01 AM »
 ;)How about that-two respondents with the same name-!.
Thanks Gregory and Greg for your postings-lots of useful data there and I am sure if I get stuck , I could get help in a flash!.
I am very exited to get the old Gal back on the air-luckily I am very technical , and LOGIC circuitry was my major at college, so it is all a matter of finding the root cause and replacing components that might fail in future-like tantalums in the power supply decoupling circuitry.
Much like the TS-850s with its' capacitor fail issues.
Will send feedback when I get her working.. Smiley
73 de William
ZS4L
ZS5WC
« Reply #5 on: April 28, 2014, 01:08:14 PM »
 ;DGot the 380 on the bench yesterday, and had a maiden transmission with her today-replaced a faulty dual op-amp in the 2nd PLL loop.
She works well--BUT, the output power seems inversely proportional to the frequency, i.e. 80m is fine at 90w PEP, 40m is lower at 30w, 20m even lower at 20w, etc..
The LPF filter board maybe?..
Any Rockwell Collins experts out there?
73 de William
ZS4L
W9GB
« Reply #6 on: April 29, 2014, 07:26:51 AM »
Re-read the September 2013 answers --
who knows this radio better than the engineers that designed and supported?
ZS5WC
« Reply #7 on: April 30, 2014, 12:18:40 AM »
 ;)Thanks , I will follow your advice and links as well!.. I am in the process of signing up with the CCA reflector too.
It seems the LPF relays are switching properly, but output power still seems low on 40m and above.
What I did not check was to see if maybe the WRONG relays are being switched.
Perhaps one bit missing to the latch circuitry.
The PA is drawing roughly the same current on most bands-I deduced this by checking the unregulated DC volt drop when key down-so it is trying to produce power.
Obviously I did this for VERY short times as I don't want to damage the PA IF there are issues.
Cheers,
William
ZS4L
ZS5WC
« Reply #8 on: May 04, 2014, 11:37:23 AM »
 :)Long story short:
I found one PT9785 open,(non original) and some damaged bias components.
I removed the PA from the heatsink and overhauled the unit.
I re-in stalled MRF454's , and reset bias. I also included Homebrew gain feedback networks to flatten gain accross the HF spectrum, and improve stability.
Works like a dream--BUT I have discovered the next problem.
On 20 and 10m the rig THINKS it is in the Ham bands, but is actually on a way off frequency.
It transmits, BUT swr is infinite into the yagi, which means the TX and RX frequency is incorrect.
For example 14.000 to 14.300 (on the dial) is FULL of arabic AM stations!. Clearly not correct.
I will determine HOW FAR wrong it is-but this is a very strange problem!.
Any ideas?.
The TX/ RX muting is also not ideal-big POP! in the LS when pressing the PTT.
73 de William
ZS4L
ZS5WC
« Reply #9 on: May 05, 2014, 11:24:59 PM »
 ???Wow!, I am amazed-nearly 8100 reads and not a single further reply?..
Where are the experts?.
Did more testing last night, on 14.200 the rig is actually on 15.200 Mhz, on 28.500 the rig is actually on 29.500 mHz.
Seems the LSB bit from the control unit to the PLL is permanently set.
Sooo-will have to trace some bits..
Repaired the coupler board-now getting proper alc action--in fact a bit too much..
73 de William
ZS4L
ZS5WC
« Reply #10 on: June 08, 2014, 11:59:17 PM »
 Grin
After fixing the PSU circuitry, repairing the PA, and replacing blown caps, I discovered that the KWM-380 would be off frequency by 1Mhz on some bands!.
I traced it with difficulty to a faulty CD 4094 serial to parallel converter on the synth. board (u18). replaced with a new one and hey presto!.
I also took the opportunity to replace most decoupling tantalum caps with new LOW ESR electrolytics.
After I replaced the synth. I got the infamous BEEP BEEP BEEP, showing synth. unlock-(HORROR!) , and I retraced this to a badly seated coax that runs between the two synth. boards--(PHEW!)
73 de William
ZS4L
ZS5WC
« Reply #11 on: June 29, 2014, 11:47:29 PM »
  Grin Grin Grin
Got SECOND KWM-380 from an SK estate on Saturday!.
Now I guess I have the only two in Africa!.
Seems as a bonus this unit has most options fitted AND I have a CW narrow filter for it as well.
Cosmetically it also looks very good.
The work on no.1 continues, audio mods and capacitor replacements..
The new LOW ESR electrolytics are great-and has the same ESR values of new tantalum caps!.
I don't fancy tantalums for decoupling applications as they always fail SHORT and this causes other problems like feeding power where not needed thus blowing other devices, or shorting out high current supply rails.
For a rig this age, I am amazed by the stability of the PLL, also considering the very early 1st generation PLL design!.
I will update as work continues..
73 de William
ZS4L / ZS5WC
ZS5WC
« Reply #12 on: January 19, 2015, 10:04:13 PM »
 :)Well so far so good-no more failures of components in the KWM-380, and even joined the 14.263 CCA net, barefoot with the KWM-380 from ZS.
I obviously should have described my repairs to the Collins fundis when I joined in, but would do so next time.
I am considering improvements to the DC to DC converter-although at the moment it is working pretty well, and I am busy replacing a couple more DC decoupling caps in various circuitry.
The old double sided boards have to handled very carefully as desoldering a chip could cause issues-eventually resorted to blowing the solder clean from the holes using a small compressor and nozzle.
I love the Rig, even on 10m she works like a dream-(with no RF preamp), and the stability is awesome.
I do note a bit of THD in the audio on occasion-maybe the audio chip needs further investigation.
Still looking for a NB board , and processor board, so anyone has any lying around, please drop us a line to ZS5WC1(AT)yahoo(DOT)com.
The second KWM380 is still waiting to be repaired and restoration-but first some shack revamping needs to be completed.
73 de William
ZS4L / ZS5WC
ZS5WC
« Reply #13 on: June 24, 2015, 05:05:15 AM »
 :)My Latest Quest regarding the KWM-380 is a KIRON memory adapter.
Anyone have one of these he would want to dispose of?.
Perhaps there is a homebrew adpater I could build using more modern devices?.
Otherwise, the Radio is performing well-I sometimes forget to either turn the PBT to usb / lsb or switch the mode switch- and then can't figure out why I am not heard-but learning slowly-Hi!.
The audio still seems slightly "fuzzy" I suspect the audio chip / audio filter.. So will investigate that further-at the moment I am just loving operating the old rig!.
73 de William
ZS4L / ZS5WC
W9GB
« Reply #14 on: June 24, 2015, 08:03:57 AM »
Kiron Corporation
1516 Essex Road
Columbus, OH 43221
USA
Company was owned and operated by Ron Long, W8GUS
1986 - 2005; company now inactive.
Ron Long, W8GUS, did NOT sell the Kiron board for KWM-380, HF-380 directly.
He stocked Surplus Sales of Nebraska with his Kiron boards ($139 each/2005 price),
for retail sales.  Last re-stock, that I am aware of, was 2005.
Contact Bob Grinnell, at Surplus Sales of Nebraska  -- to see if they have any remaing stock
Kiron Memory Adapter (KWM-380) Manual
http://collinsradio.org/archives/manuals/Kiron%20KWM-380.pdf
Mack McCormick, W4AX developed his own board for KWM-380.
http://www.collinsradio.org/mack-mccormick-w4ax/
W4AX still had boards and parts.
The keypad used is from Pico (still mfg.)
310 Dancers Way
Milton, GA 30009
eHam.net Review - W4AX board
http://www.eham.net/reviews/detail/10221
IF you don't know Mack, he is another master restorer.
This YouTube video (2013) shows his "Ham Shack".
http://youtu.be/0XxdR_QZG2w
Almost every boatanchor you will see (3:00 point on) in the YouTube video
was junked/bad condition -- and he completely restored.
Like master woodworking, classic car restoration -- the work requires HOURS.
« Last Edit: June 24, 2015, 08:42:14 AM by W9GB » Logged
