Author Topic: Repeater squelch will not work  (Read 31271 times)
K4JJL
« Reply #15 on: October 11, 2013, 05:51:45 AM »
Here's the manual on your IDA repeater board.  I've never used one.
http://www.repeater-builder.com/ge/lbi-library/lbi-31807d.pdf
I always do my repeater interfaces through the tone remote interface (which I doubt your unit has).  It has a nice compressor/limiter that evens out the audio nicely.  The are mainly found only on units with the large card slot cage.
K4JJL
« Reply #16 on: October 11, 2013, 06:00:56 AM »
Just gave that GE manual a quick read-over.  No dice on the build-in ID.  It only controls timeout timers, drop out delays, and gives an alert tone for a dead battery back-up (all that was required on commercial set-ups of the day).
If you're going to use an ID-O-Matic, I'd suggest wiring it to the local mic connector (with appropriate DC blocking capacitors and level-adjusting pots).  You're still not going to get set-up and knock-down, courtesy tones, and voice announcements that come with a real controller.
