Author Topic: UHF on a VHF Rig (updated)  (Read 6598 times)
VU2NAN
« on: November 07, 2013, 10:18:32 AM »
Please do check this out.
http://nandustips.blogspot.in/2011/02/uhf-on-vhf-rig.html
Nandu.
AB9NZ
« Reply #1 on: November 09, 2013, 06:10:57 PM »
What a beautiful little transverter! Thanks for sharing Nandu.
     73 de Tom AB9NZ
« Reply #2 on: November 10, 2013, 05:22:24 AM »
Just be careful that the radiation at 120MHz from the 70cms antenna - there will be some - doesn't give a problem for aircraft. Also, any strong FM BC stations in 94 - 96 MHz can mix with the 4th harmonic  and come out in 2m.
« Reply #3 on: November 11, 2013, 05:57:07 AM »
Depends on the 70cm antenna performance at 120 MHz - and its impedance at 120MHz and the leakage inductance of the tuned circuit etc. In Europe, all the receiver radiation is required to be -57dBm conducted to the antenna for frequencies below 1GHz. That probably means getting some 60dB of attenuation...
More of a problem is the FM broadcast breakthrough if there are strong local signals in 94 - 96 MHz - also breakthrough from DAB operating around 216 MHz.  Adding a quarter wave short circuit coax stub at 70cms across the input would help enormously - about 12cms would do it with solid polythene dielectric coax. It would help with radiation, too.
« Reply #4 on: November 11, 2013, 12:16:57 PM »
Nandu,
You are welcome! Good luck.
Peter G3RZP
