Author Topic: Amateur Radio Transceivers With GPS NMEA-0183 Output  (Read 13701 times)
N0JS
« on: November 26, 2013, 08:54:16 PM »
Does anybody happen to know what amateur radio transceivers have NMEA-0183 output?  I am considering buying a mobile and if it has GPS built into it with NMEA-0183 output, I would like to feed that data to a Uniden Home Patrol HP-1 scanner.
K0JEG
« Reply #1 on: November 28, 2013, 05:55:50 PM »
The TH-d72a outputs an NMEA data stream over the USB port. However, since it's a USB device you'll have a very hard time interfacing it to your scanner. There is a serial port on the D72 but it is made for interfacing a weather station.
You might have better luck with a "puck style" GPS like the Garmin GPS-18. Just make sure it has an RS-232 style serial port and not USB.
W7ND
« Reply #2 on: February 26, 2014, 04:57:17 PM »
While not a transciever, the GPS-710 from Greenlight labs has a NMEA-0183 output port.  I don't know if it can be used independent of a Kenwood D710 for gps output though.
W5LZ
« Reply #3 on: February 27, 2014, 01:39:34 PM »
For what it's worth, there's a 'new' model of the TM-D710, the "G" version, that has a GPS built into it.  No idea if it would suit your purpose.  Sit down before looking at the price of that thing!
 - Paul
KF7CG
« Reply #4 on: February 28, 2014, 09:46:12 AM »
I do not have the spec's on the Yaesu FT1D handies but they have built-in APRS with GPS and can output the GPS throught their USB port.
I don't have my manual handy for mine at work or I would look it up. The new digital mobile radio might have it also.
KF7CG
