Author Topic: TV RFI when keying up on 2 meters  (Read 5823 times)
KK4SUH
« on: December 02, 2013, 06:51:08 AM »
I get TV OTA using two dipoles in the attic;an old 11 meter dipole somebody gave me a few years back and a vhf dipole I recently made that feed into a T connector which is connected to the coax that feeds into my TV's (I know it sounds crazy, but I had to use them together to get most of the stations available to come in.)  I did have an amplifier on the line that I have since removed that has improved the situation a bit (I no longer completely overload the receivers on the TV's when keying up) , but even if I just key up on my HT on 1W it still causes problems with channel 7.  It only occurs if I key up from around 144.600 to around 145.900.
Would a notch filter work, and where can one be purchased for the 2M band?
KB4QAA
« Reply #1 on: December 02, 2013, 10:21:48 AM »
Unlikely you will find a single channel notch filter for sale, though one can easily be built.  Without looking up the present TV channel frequencies, a Band Pass filter (probably Low Pass) may work.   Possible sources:
DX Engineering,
Morgan Manufacturing   http://www.morganmfg.us/
The standard list:
-Reduce power
-Re-orient the antenna
-move the antenna further away/higher
-Tidy up:  straighten out (TV) cables, power cords, don't overlap, coil up unused lengths, attach chokes close to TV (that appropriate Mix for the frequencies in question).
-place covers or even aluminum foil over any cable F type connectors not in use.
-Simplify your setup for troubleshooting.  Remove the second TV antenna.  Work with only one antenna.
-Borrow a different TV and see if it has the same interference.
Realistically, a 1w HT shouldn't cause interference to a TV.  If all else fails you may need to get a different TV, or coordinate your hamming so as not to bother the family.
KK4SUH
« Reply #2 on: December 02, 2013, 11:36:26 AM »
I started by removing pieces of coax to reduce number of connections and overall length and channel 7 went completely out. I tried only using one antenna, no luck.  I did try another TV this morning and it experienced the same interference. I don't have any extra chokes on me right now, so I couldn't try that. I haven't tried moving around the antenna yet as it's a bit of a pain to move around but I'll try it when I get a chance.
KF7CG
« Reply #3 on: December 03, 2013, 06:33:31 AM »
Go to a frequency chart an find the frequencies for channel 7. I believe that it is just above the 2Meter band. The frequencies mentioned might be an image to channel 7. It also sounds as thought 7 is somewhat marginal in your area, again a problem.
You need, if you can find one, a 2 meter band-reject fileter for the TV antenna feed. Place it as close to the TV as possible.
KF7cg
KH2G
« Reply #4 on: December 03, 2013, 10:41:31 AM »
Toss the TV and get on with life. No one needs a one eyed monster. The old ones that had power transformers at least were usable for junk parts.
Regards,
Dick KH2G
