Author Topic: Magnetic RFI  (Read 5845 times)
RSHIRE22
« on: December 06, 2013, 06:50:07 AM »
I homebrewed a magnetic loop antenna which works well but as predicted magnetic rfi is wreaking havoc with my computer especially the clock which I need to run JT-65A. I use a coax choke in the shack and a toroid isolator at the feed point which don't suppress magnetic rfi (at least not in my case). How do I suppress magnetic rfi in shack?
Any suggestions are appreciated.
RSHIRE22
« Reply #1 on: December 06, 2013, 09:04:11 AM »
I guess magnetic rfi is EMI.
Boy there is an abbreviation for everything!
KB4QAA
« Reply #2 on: December 06, 2013, 10:54:43 AM »
Magnetic RFI.  sigh. Wink
Try the term "Small Loop Antenna" and we can start to get away from the idea that these antennas have special properties or unique RFI modes.
Your problems are quite common, and asked several times every week.  The answers are repeated several times every week.  Smiley   I recommend reading other posts in the forum for better understanding.
Anyone who thinks that having antennas inside or close proximity to a house, attic, apartment or townhouse (like me) without a very high probability of RFI problems is naive.
The Standard Laundry List:
-Reduce power.  Find a level that doesn't cause problems.
-Change bands.  Operate on bands that don't cause problems
-Re-orient the antenna
-Move the antenna higher, farther away
-Good housekeeping:  Straighten up cables, don't cross, coil them up, put frequency appropriate Mix chokes on all cables close to each end.
-Use chokes, isolation transformers/baluns in the antenna coax
-If using amplified speakers, switch to passive speakers
-Study up on shack ground systems.  Eliminate ground loops in/between coax and 'ground wires'.
-Keep ground leads/wires/braid/foil wide and as short as possible.
-Don't use electrical grounds for RF purposes.
-Avoid RF grounds that are resonant lenghts or longer, e.g. 1/4wl or longer.
That's a start.  good luck.  b.
« Last Edit: December 06, 2013, 11:03:10 AM by KB4QAA » Logged
RSHIRE22
« Reply #3 on: December 06, 2013, 09:27:42 PM »
Thanks b. I moved my transceiver about five feet away and put aluminum foil on all the cables. I am running 50 watts with about 15% efficiency. So far it's better now running JT-65HF. I can't use WSJT at all. At 49 seconds past each minute the software clock freeses.
I've read through your suggestions and see which are practical.
Ron
