Author Topic: USB Problems...  (Read 5394 times)
K5TED
« on: December 30, 2013, 03:54:59 PM »
...not an issue here.
« Reply #1 on: December 30, 2013, 04:58:54 PM »
XP, got to love it.  It appears that you have unplugged and reinserted that device at least 4 times. Plug n play on XP is not that good and when your remove and reinstall a device from a USB port it reinstall it on another port even though it is the same device. The cure is to uninstall all of them and reboot and then plug device back in to reinstall and leave it in. Newer OSes are a bit better about this.
K5TED
« Reply #2 on: December 30, 2013, 06:51:46 PM »
They are all active devices, all playing together, all the time, on Windows 7 64 bit.
« Reply #3 on: December 31, 2013, 07:14:41 AM »
What are you using 11 com ports for?
K9IUQ
« Reply #4 on: December 31, 2013, 08:13:31 AM »
K5TED's setup is not particularly unusual for a sophisticated hamradio setup.. I have 13 USB comports, 10 of which are in use and active all the time...... I could use all 13 at the same time if I wanted too. No problems, I have done it.
On my setup:
6 ports used for Navigator Digital Interface
1 for QS1R SDR
I for TS-590s ARCP control software
1 for Public Service Scanner control
1 for Cyberpower UPS monitoring software
3 others that are not used all the time.....
1 for Icom 7100 control software
1-Baofeng programming software
1- Blood Pressure Monitor Software
I use Win7/64.
Stan K9IUQ
« Last Edit: December 31, 2013, 08:17:05 AM by K9IUQ » Logged
K5TED
« Reply #5 on: December 31, 2013, 09:15:45 AM »
Ports:
Eltima 4/14, 5/15 is Flex 3000 CAT/PTT control
Keyspan USB 6 - FT-857D control
Keyspan USB 7 - FT-847 control
Keyspan USB 8 - Icom PCR-100 control
Keyspan USB 9 - Icom PCR-1000 control
Keyspan USB 12 - Kenwood TS-140S control
Prolific USB 10 - FT-817ND (for programming)
Sound USB devices:
iMic USB - Left channel is IF input from Icom PCR-100, Right channel is IF input from FT-857D for use with HDSDR, SDRadio, DSP, etc.
USB Audio Codec is Signalink on Kenwood TS-140S
USB Audio Device is SB Audigy for FT-857D data modes and audio bridging/monitoring/Voice Shaper/DSP
Other USB:
Keyboard
Mouse
Griffin knob
KG4RUL
« Reply #6 on: January 01, 2014, 05:01:26 PM »
I also have multiple USB devices plugged in at any one time.
on My XP Machine:
HP Inkjet Printer
Canon Laser Printer
PSK Meter
SignaLink USB
Keyboard
Mouse
A couple of Thumb Drives
Serial Converter for TS2000
I also use a port for Arduino program development
On my WIN7 Machine:
Canon All-In-One Inkjet
Label Printer
Trackball
Keyboard
Backup Drive - 1TB
Webcam
Speakers
Headset
