Author Topic: Flash player for ipad mini  (Read 9014 times)
HG5AZR
« on: January 05, 2014, 09:49:27 AM »
Hi!
I have apple  ipad mini with ios 7 operation system.
I like to play same video,I got following: you need to installed flash player and java supported browser.
Any suggestion to solve problem?Free?
Thanks
             Zoli
K1OC
« Reply #1 on: January 05, 2014, 06:37:51 PM »
Flash is not supported on iPads/iPhones. Maybe see here http://ipad.about.com/od/Productivity-Apps/tp/How-To-Play-Flash-On-The-iPad.htm for possible workarounds.
Good luck!
73 de Tony
N0IU
« Reply #2 on: January 05, 2014, 07:12:59 PM »
Where did the other replies go???
N0IU
« Reply #3 on: January 05, 2014, 09:08:17 PM »
Too late to edit...
My apoligies. I replied to the same question on another forum and I thought it had been deleted from this one.
HG5AZR
« Reply #4 on: January 06, 2014, 01:24:43 AM »
Hi !
1. Can I download java for ipad mini ios 7 operation system?
2.Can I download java for android 4 mobile phone?
Thanks
             Zoli
« Reply #5 on: January 06, 2014, 07:32:56 AM »
yes
yes
While Apple refuses to support Flash (because they want you use/buy their content) they does support Java because it would hurt them  lot in market place if they did not. BTW IOS is only main stream tablet/smart phone OS that does not support flash
KE7TMA
« Reply #6 on: January 06, 2014, 11:04:09 AM »
Actually there is no Java on any iOS device.
« Reply #7 on: January 06, 2014, 12:08:11 PM »
Not as it comes from Apple anyway. Will Apple does not support it, it is possible to install support for it. Microsoft has not supported Java for many years too but it is easy to install.
W5ARP
« Reply #8 on: January 08, 2014, 02:44:07 PM »
Actually, java is a dying platform on the user side, i.e. JavaSE (still popular on servers though, JavaEE).  iOS, Android, and Windows RT (i.e. the Surface) don't have a JVM (Android is actually programmed in Java, but cant run JavaSE apps).  The Surface pro is intel windows so you can install Java there.  Flash is also getting less supported, but not as bad as Java.  Flash has never been supported on iOS, it is no longer supported on Android.  Flash does work on both versions of Windows though.
KE7TMA
« Reply #9 on: January 08, 2014, 05:35:11 PM »
That's technically true.  It's possible to run any Unix application on a jailbroken iOS device, if it is compiled properly.
