Author Topic: Snow and HF  (Read 14666 times)
WX2S
« on: January 21, 2014, 02:53:12 PM »
I'm seeing a lot of QRM on 40 now in the snowstorm. Static bursts. Could the snow be causing it?
73, wx2s.
73, - Steve WX2S.
« Reply #1 on: January 21, 2014, 02:59:03 PM »
My guess here is arcing on insulators on power lines from snow build up that 85 being burnt off
W6QW
« Reply #2 on: January 21, 2014, 03:42:33 PM »
Another possibility is electrostatic buildup on your antenna if the antenna is not at DC ground potential.  I have personally gotten zapped by a static buildup on a large vertical antenna during a rain storm (as you probably remember, your coax is a capacitance to ground from the coax center conductor if that center conductor is not at DC ground potential).  A quick test by disconnecting the antenna and placing the center conductor about 1/32 to 1/16 inch from DC ground will yield an occasional spark if EMF buildup is your culprit.
WA2ONH
« Reply #3 on: January 21, 2014, 04:40:00 PM »
LINK: http://www.repeater-builder.com/products/static-buster/buster.html
ELECTROSTATIC RECEIVER NOISE
By Mike Norton KE4NS
"Precipitation Static
This occurs when electrically charged particles (raindrops, snow, dust, etc.) strike the antenna tower, antenna boom or elements, inducing a current impulse in the element and thereby producing broadband noise. This noise called precipitation static is generally defined to include all external atmospheric electrical effects which produce electromagnetic interference."
73 de WA2ONH   ... Charlie
"Never be satisfied with what you know, only with what more you can find out"   Dr David Fairchild 1869-1954 US Scientist
KS2G
« Reply #4 on: February 16, 2014, 04:12:59 AM »
Just to pick a nit:
That would be QRN ("N" for noise).
QRM is interference ("M" for man-made).
See: http://www.ac6v.com/Qsignals.htm
Mel - KS2G
KJ6ZOL
« Reply #5 on: April 02, 2014, 01:21:08 PM »
Just to pick a nit:
Mel - KS2G
I always remembered it by "N for Natural noise, M for Man-made noise". In reality, the M and N don't mean anything. But if a little mnemonic helps, great.
