Author Topic: MMSSTV Can't transmit templates  (Read 3216 times)
KD1I
« on: March 31, 2014, 05:34:57 PM »
Recently I decided to get back into SSTV and MMSSTV looked like a very good program to try. It receives well and I can transmit as well, however, there is one oddity as dragging a template to the transmit window causes it to jump back to the template window. I feel this must be a setup configuration error on my part but I cannot transmit the templates overlaying an image in the transmit window. I read the documentation for MMSSTV and I searched on MMSSTV in E-ham as well but I do not see anything like this.  This is what I have done so far:
1. Right click on template window, select Options - Show transmit picture is checked.
2. Then on Stock Pictures, "Show with Template" is checked.
3. Draft is not checked.
4. When I go to the transmit window, the template is gone.
I thought selecting "show with template" would have cured this but it did not.
So while I can transmit any image in the transmit window, I cannot transmit the image with a template overlay.   What am I doing wrong here?
Many Thanks and 73, Jim       KD1I
KD1I
« Reply #1 on: March 31, 2014, 07:02:50 PM »
OK, I solved my own problem.........    Click on the transmit window.  At the bottom of this window is an "ABC" button. Press this and VOILA, it works just fine.    The template or overlay will stay on the transmit image.   All I can think to say is "DOH"!!!
