Author Topic: FT-747GX s-meter lamp  (Read 12790 times)
KG5UN
« on: April 01, 2014, 12:44:46 PM »
I have been unable to come up with info on replacing the s-meter lamp in a Yaesu FT-747GX.
Does anyone one have the specs or a source?
W9GB
« Reply #1 on: April 01, 2014, 04:30:56 PM »
Yaesu FT-747GX Service Manual (Technical Supplement)
http://w5jgv.com/downloads/FT-747%20Technical%20supplement,%20A3.pdf
Page 3 : S-meter is Yaesu part # M0290057
Page 12 : DISPLAY UNIT - PC Board X-Ray and Component layout.
Page 13 : Schematic Diagram of Display Unit.
ALL of these Lamps are 8 Volts, T-1 in size (grain of wheat), and mounted (soldered) to this PC Board.
Page 37 : PARTS LIST for Display Unit
Display Backlighting Lamps: PL01 and PL02
S-Meter Lamp: PL03
PL3001, PL3002, PL3003 : Yaesu Part # Q1000010 : Lamp : 8 V, 100 mA : OEM Part # BQ041-22803A
Fox Tango Discussion
This SAME Lamp is used on main RF Board as Protection for Front End of Receiver (FD1; F1001)
http://lists.contesting.com/_yaesu/2003-05/msg00025.html
June 2013 discussion (QRZ) on this same topic
http://forums.qrz.com/showthread.php?393577-Sources-for-FT-747GX-Battery-Replacement
WY3A Information for Lamp Replacement
http://www.qsl.net/wy3a/Lamp_Fuse.htm
« Last Edit: April 01, 2014, 04:57:25 PM by W9GB » Logged
KA4POL
« Reply #2 on: April 01, 2014, 09:48:28 PM »
You also might consider exchanging the lamp against an LED with a resistor to keep the current down.
KG5UN
« Reply #3 on: April 02, 2014, 06:23:19 AM »
Thanks for the help. Current draw is not really an issue, just looking for a simple solution.
Perhaps a 3.3 volt led with a dropping resistor would be easy.
KA4POL
« Reply #4 on: April 02, 2014, 06:39:37 AM »
Main thing is the eternal life of a LED, unless you overpower it  Wink
KG5UN
« Reply #5 on: April 02, 2014, 08:21:36 AM »
I found a mod suggesting a 3.3v led and a 220 ohm 1/2 watt resistor. I think that is the route I will take.
thanks.
W9GB
« Reply #6 on: April 02, 2014, 04:09:36 PM »
BTW, supplies are PLENTIFUL of this bulb / front-end fuse in UK.
G-WHIP has over 300 of these original Yaesu antenna fuses (FT-757/ FT-102)
 Q1000010 F359A BQ041-2783A, approx 10 ohms in value.
http://www.gwhip.co.uk/radiospares.htm
Geoff does have his store closed the next 3 weeks for Spring/Easter vacation.
G-WHIP - Southampton, UK acquired these from former Yaesu UK/EU parts warehouse.
« Last Edit: April 02, 2014, 04:25:11 PM by W9GB » Logged
N4NYY
« Reply #7 on: April 03, 2014, 04:39:48 AM »
thanks.
If that is a 12V (13.Cool, I would use a 470 or 560, just to be safe. Nothing will happen other than burning out your LED. But at least you do not have to rip it apart. You would have to measure the supply voltage and then use online calculators.
BTW, I do these mods all the time. Use a flat LED. They are 180 degree dispersal of light. Rounded LED give you a spot effect. Also, there are some kooks that will tell you to sand a rounded LED down flat. That is one of the dumbest things and biggest wastes of time you can do. Flat LEDs are dirt cheap.
W9GB
« Reply #8 on: April 03, 2014, 11:58:13 AM »
If that is a 12V supply ...
NO, Yaesu uses an + 8 Volt rail for the 3 lamps (bulbs) on front panel,
as noted in my earlier answer (April 1, BUT not a "punked" answer.)
Incandescent Lamp is 8 Volts, 100 mA.
Lamp : 8 V, 100 mA : OEM (East Asia) Part # BQ041-22803A
« Last Edit: April 03, 2014, 12:00:48 PM by W9GB » Logged
N4NYY
« Reply #9 on: April 03, 2014, 05:12:57 PM »
OK. Good info. So the online calulator would be useful with that supply voltage. That 220 may be OK.
