Pages: Prev 1 2 3 4 5 [6] 7 8 Next   Go Down
Author Topic: What ham radio BS have you heard?  (Read 65029 times)
W9FIB
« Reply #75 on: June 16, 2014, 11:46:35 AM »
You can tell inflation has kicked in over the years.... these days, it's 599.....
Seen in a very old issue of QST:  "Everyone is 599 on my S meter!"    Grin
Guess someone couldn't figure out that the S meter reading is only 1/3 of the 599 report!
73, Stan
Walk a mile in my shoes BEFORE you tell me how bad they are.
KG7CSS
« Reply #76 on: June 16, 2014, 01:00:52 PM »
Usually go with  Chinese radio are junk: as part of a debate on one of the repeaters.
you get what you paid for: More expensive the better the radio .
I can never cannot understand that logic why pay $150+ when a $35.00 works.
W4KYR
« Reply #77 on: June 16, 2014, 01:03:59 PM »
Heard on 10 meters more than once
" You are 599 ....What is your call? .... One more time please........no copy........QRZ"
WA2ISE
« Reply #78 on: June 16, 2014, 02:13:38 PM »
Now that you mention it, I think it was "Everyone's S9 on my meter!"   Smiley
WA7PRC
« Reply #79 on: June 16, 2014, 02:17:36 PM »
The S in RST is the S meter reading.
No. While some believe it is the S meter reading, it is and always has been simply a qualitative (not quantitative) measure of signal strength.
While an S meter reading of 9 is supposed to equal 50uV across 50 Ohms, many receivers do not conform to that.  Also, even if two receivers meet that specification, they typically do not conform to the 6dB/unit standard.  And then, you have antenna gain/loss.  A fullsize yagi is going to present more signal to the receiver than an IsoLoop "antenna". And then, you have atmospheric and local noise conditions. An S-meter reading of S9 is a lot harder to copy when the noise is competing with that signal, while a signal level of S4 is easy copy when the noise is quite a bit less.
W3ESE
« Reply #80 on: June 16, 2014, 02:36:19 PM »
Antenna Wire Wax...
Great for filling in those "microscopic imperfections" in all types of antenna wire, so the RF can escape more easily...
Get yours today!.... Grin
« Reply #81 on: June 16, 2014, 02:39:30 PM »
RST: S = "Strength" is measured on a scale of 1 to 9.
1.Faint signal, barely perceptible
2.Very weak
3.Weak
4.Fair
5.Fairly good
6.Good
7.Moderately strong
8.Strong
9.Very strong signals
K6MGK
« Reply #82 on: June 16, 2014, 04:08:54 PM »
Heard on the ham bands today between two disgruntled hams, that the majority of the hams in the  southern part of the US are married to there sisters!!!
KA5PIU
« Reply #83 on: June 16, 2014, 05:15:41 PM »
Hello.
RST.
https://en.wikipedia.org/wiki/RST_code
Now, most if not all commercial HF radios have no S meter, or it is buried in the operators console somewhere.
So, here is one simple question?
Why is it so important?
K4EJQ
« Reply #84 on: June 16, 2014, 07:31:52 PM »
NO antenna will work without a BALUN!!!! The ham radio community is full of "mistaken certaintities ", HI
              73, Bunky, K4EJQ
W9FIB
« Reply #85 on: June 16, 2014, 07:49:23 PM »
2 reasons actually, 1 that's all most hams in communist countries can tell you; and 2 that's all some people know how to say on the radio.
Another reason is most contests use a signal report as part of the exchange. So for contesters, it is real important.
73, Stan
« Reply #86 on: June 16, 2014, 09:32:31 PM »
Well, that's an easy one. 100W amplified to 1000W is a 10dB difference. At 6dB per S Point that's under two S Points. A decent RF speech processor and a communications quality microphone would be far more effective.
Peter DL8OV
Not on CW.
KA5PIU
« Reply #87 on: June 17, 2014, 03:24:15 AM »
Hello.
CW needs power, less power than any other mode, in theory.
But, if CW is so efficient, why so much power?
« Reply #88 on: June 17, 2014, 05:49:46 AM »
Path loss.
WA2ISE
« Reply #89 on: June 17, 2014, 12:37:56 PM »
Not on CW.
Damm, and I was using phonetics on CW too.   Grin
Pages: Prev 1 2 3 4 5 [6] 7 8 Next   Go Up
