Author Topic: Date used in log  (Read 8772 times)
KK4EOF
« on: June 14, 2014, 03:44:15 PM »
HI all.
I am not sure what date to use in my log.  I always use UTC time, but do I use the local date or the date in Greenwich, England?  What about international contacts, do you use the date in the country you have contacted or your own local date?  Or does it even matter?  I am assuming that the software that checks qsos for LOTW or whatever will invalidate a contact if the dates are different by a day.  That could screw up getting credit for DXCC or other awards.  What does automatic logging software do, use the os system date, or does it adjust based on the DX entity you're logging?
« Reply #1 on: June 14, 2014, 03:57:20 PM »
Use the UTC time and date. It is the same everywhere in the world.
KA5PIU
« Reply #2 on: June 14, 2014, 06:36:26 PM »
Hello.
As a rule, you use UTC or YOUR local time.
Stay consistent.
Some prefer UTC as it solves the problem with daylight savings time.
Thank you.
KS2G
« Reply #3 on: June 14, 2014, 06:43:28 PM »
As AA4BP said ... use UTC time and date.
Be sure you take Daylight Saving Time into account when you do the conversion from local time to UTC.
In your case (being located in Florida) -- UTC is 5 hours ahead of Eastern Standard Time (the date changes at 7pm your local time) and 4 hours ahead of Eastern Daylight Time (the date changes at 8pm your local time).
KG4RUL
« Reply #4 on: June 14, 2014, 06:54:50 PM »
OR
Maintain a station clock that is set to UTC
KS2G
« Reply #5 on: June 14, 2014, 08:16:57 PM »
OR
And don't change it when Daylight time starts/ends.  Wink
K7KBN
« Reply #6 on: June 14, 2014, 09:35:56 PM »
HI all.
Think...if you're using UTC, and it's midnight UTC, does the date in Greenwich change?
Pat K7KBN
CWO4 USNR Ret.
KI6LZ
« Reply #7 on: June 14, 2014, 09:41:49 PM »
Time and date are referenced to UTC. This avoids the problem of every country having different local times and dates. And yes, all logging should be in UTC date and time. I've had some that use local and it messes me up.
Don't know why the underline for all. Oh well.
M6GOM
« Reply #8 on: June 15, 2014, 03:39:30 AM »
Decent logging software should do it all for you regardless, automatically converting all logs to UTC from local.
N0IU
« Reply #9 on: June 15, 2014, 07:08:38 AM »
Hello.
Stay consistent.
Thank you.
With all due respect, this is really, really BAD information!
Remember, the "U" in UTC stands for "universal". If you send the other station a paper card with your local time, they will send it back to you with the comment "NIL" (not in log) if you are lucky. Most likely, they will just throw it away. If you use an electronic confirmation service like LoTW or eQSL, you won't get a confirmation since the times must match +/- 30 minutes.
ALWAYS use UTC!
WA7PRC
« Reply #10 on: June 15, 2014, 09:05:00 PM »
ALWAYS use UTC!
Ditto.
K1PJR
« Reply #11 on: June 16, 2014, 05:18:45 AM »
Your log should automatically enter the date based on UTC.  At first i would enter the date manually until I received an email from an op saying I had the wrong date on my QSL card.  Always use UTC and date.
KB2WIG
« Reply #12 on: June 16, 2014, 07:06:34 AM »
time.gov   is nice... Just click the arrow until you c utc.
WWV/
WWVH/
WWVB/
MSF/
JJY
CHU
or
http://www.lownoiserecords.com/wwv_the_tick.html
klc
EXTRALight  1/3 less WPM than a Real EXTRA
N3QE
« Reply #13 on: June 16, 2014, 07:35:35 AM »
UTC date and time. Never anything else. When it rolls over to 0000Z in our evening, it is "tomorrow" UTC date.
Rules for LOTW matching:
What constitutes a QSO "match?"
To match, the two QSO records (yours and the other station's) must have:
Call of each QSO matches own call of the other (including portable identifiers)
The modes are in the same mode group (e.g., SSB and PHONE match because both are PHONE)
The date/time values are the same within 30 minutes (all times are UTC)
KB2FCV
« Reply #14 on: June 16, 2014, 10:08:21 AM »
Exactly this.. as other posters stated.. if you have the wrong date, you'll get a NIL most likely if you send a QSL. It's pretty much standard that UTC is used for time in date in terms of logging, etc.
