eHam Forums => VHF / UHF => Topic started by: KM4ODW on February 27, 2017, 04:05:52 PM
Title: Icom IC-2300H
Post by: KM4ODW on February 27, 2017, 04:05:52 PM
I have a IC-2300H that was working until I was working on the truck. Radio was off but connected power lines backwards. As soon as I saw the spark I pulled the wire. Now the weird part. I can receive fine. When I transmit, my SWR meter is showing 50 watts on 2 meters. But when trying to hit a repeater, no response. Checked Freq (147.28500), Duplex (+) and offset (203.5hz). Tried with my Baofeng HT on the same antenna and repeater responds.
Any one have a suggestion on what to look?
Thanks
Title: RE: Icom IC-2300H
Post by: K5LXP on February 27, 2017, 06:02:18 PM
If a wattmeter is showing output, it's transmitting somewhere.  Best case scenario is the power insult scrambled something.  Try a factory reset and see if that resolves it.  If not, a frequency counter can tell you where it's actually transmitting.
Post by: KM4ODW on February 28, 2017, 03:42:27 AM
Thanks Mark for the suggestion. I'll try a reset today and see what happens.
Post by: KM4ODW on March 01, 2017, 07:04:00 AM
Did a reset and a CPU reset and still nothing. I do not have a frequency counter but I connected the Icom to my base antenna and nothing. Set to simplex and can receive on my HT and the Icon can receive from my HT.
Any ideals before it goes in the trash?
Thanks
Earl KM4ODW
Middleton, TN
Post by: SOFAR on March 01, 2017, 07:45:28 AM
Thanks
If a simplex test works, I would double check the offset and PL tone.
Offset 203.5hz, a typo?
Are you pressed for time? This post gives me the impression that someone's in a hurry.
Post by: KM4ODW on March 01, 2017, 09:24:40 AM
No, not presses for time, I'm retired!!!! :D
ARRL repeater guide 2016-2017, page 347, Corinth, FM, K5WHB, 147.28500, +, 203.5 Hz. But thanks, that made me double check both radios settings. Always a good thing to do when things do not work.
Post by: SOFAR on March 01, 2017, 09:37:16 AM
I noticed the positive offset. But I would confirm that the transceiver is transmitting 600 kHz up, on the repeater input frequency.
I realize 600 kHz is usually the default on newer radios in the U.S., but it can get changed.
Post by: K4JJL on March 01, 2017, 10:53:05 AM
Easiest way to check is to plug into a service monitor and see what it's transmitting (output power, freq, audio, tones, etc).
Post by: K0CBA on March 01, 2017, 06:28:47 PM
You can't out run a spark;   once that happens, it's tooooo late to avoid damage.
Post by: WB8VLC on March 03, 2017, 10:24:38 PM
IC9, the final amplifiers power control gets its DC input directly from the battery input and it produces the Vdd (drain voltage) for the output transistor
IC9's function is to maintain the transmit output power at a constant level.
When you reversed the battery connections and let the magic smoke out you probably damaged IC-9.
On the positive side, IC-9 may have isolated the high priced final amps Vdd input from the battery and there's a good possibility that the output amplifier may not be damaged, you only damaged IC-9 .
Post by: KM4ODW on March 05, 2017, 03:29:05 PM
Can I find a IC-9 and replace it for that old of a radio?
Post by: K4QE on March 05, 2017, 08:40:47 PM
The IC-2300H is not an old radio.  It is in current production.
