eHam Forums => Computers And Software => Topic started by: WB6RLC on November 18, 2010, 11:22:42 PM
Title: Complete computer controlled radio for quadriplegic.
Post by: WB6RLC on November 18, 2010, 11:22:42 PM
  My club has taken on a project. There is a young man who would like to become a ham. He also has Muscular Dystrophy and is a quadriplegic. To operate his computer, he uses an IR link attached to one corner of his eye glasses to a receiver on his desk and a small “clicker” he uses with his left hand. His speech is pretty good. He wants to use HF SSB and maybe go digital.
 So...I am looking for suggestions on HF rigs and possible programs to run them. I do some PSK31, but other than that, I am pretty much lost on even where to start.
   Glenn
Title: RE: Complete computer controlled radio for quadriplegic.
Post by: W8JX on November 19, 2010, 06:28:58 AM
I would suggest you look at a Kenwood TS-480 SAT. It has excellent remote control ability with supplied software by Kenwood and it is a pretty decent radio too. I know because I have one here as a extra rig and i am still impressed with its performance and noise reduction under poor conditions and clean receiver. Easy to add speech too as well if you want too.
Post by: KB1NXE on November 19, 2010, 08:37:04 AM
There are the FLEX radios that are Software Defined and computer controlled.
http://www.flex-radio.com/
Most of your currently produced radios can be controlled via HRD and DX Lab Suite.
http://www.ham-radio-deluxe.com/
http://www.dxlabsuite.com/
Post by: W8JX on November 19, 2010, 02:37:43 PM
The problem with a Flex radio here is that they can take a lot of computer resources to run meaning a newer computer and if you multitask the computer it could because burdened if not pretty powerful whereas with a regular radio that is simply computer remote controlled there is far less overhead and resource demand on computer hardware and this is a consideration for someone that has motor control problems and is totally dependent on computer and you want a system with low resource draw and as reliable as possible.
Post by: KB1NXE on November 19, 2010, 08:03:24 PM
Agreed.  Hence, the info about HRD and DX Lab Suite....
Post by: W8JX on November 19, 2010, 08:15:07 PM
Yes that has merit but native software for say a Kenwood would give you full menu control as well. Another radio to look at might be a Kenwood TS-590 as it has a USB interface for remote control and it also supports full audio in and out on this connection as well opening up some interesting remote control possibilities. BTW, I am not implying that Kenwood is only solution here but i am familiar with their control software.
Post by: KB1NXE on November 22, 2010, 01:39:45 PM
The advantage one of the integrated suites of software has over the native Kenwood (or soon - Icom) software is just that.  They are integrated suites of rig control, logging and digital modes (as well as ancillary control over devices such as rotators and Coax Switches).  These benefits are surely helpful to a handicapped HAM who is unable to keep a written log or press buttons on a rotor controller.
For instance.  In my shack right now, I have a system using an Icom 756 PIII (could just as well be any modern rig from any manufacturer), IC-PW-1, Wave Node WN-2 Tail Twister Rotor with Idiom Press Rotor EZ Card with Serial option and a home brew Coax Switch.  I am able to change bands using HRD and Frequency, and the Amp, Coax Switch all track.  Those changes can be made with a mouse click.  Once I find someone in the HRD log that I'd like to try and work (via the built in DX Cluster window) I double click on that call and it QSYs to the frequency.  The Coax switch selects the correct antenna.  A right Click and an ADD and I now have all the other stations info in a log window with heading and distance info as well.  Click on the heading info and the rotor slews over to the correct heading.  So, I call the other station and he hears me.  Since it's an integrated suite of software, the log pulls in Frequency and mode info, the time is populated and since it is connected to the Internet, it pulls in the stations QTH and other pertinent info from QRZ.COM.  With the Wavenode WN-2 I am able to toggle power supplies or other controls as well as monitor power levels for 4 devices and the DC power supply.
These are things that cannot be done by a rig control program alone.
Just my nickles worth.
Post by: W8JX on November 22, 2010, 05:40:26 PM
This has merit but these package software setup cannot exploit the features on the radio the way native software can.
Post by: WB6RLC on November 22, 2010, 05:53:38 PM
Lots of good info here. Keep it coming. He lives in a group home, with about 10 other “clients”, so a rotor and beam are not an issue. We will most likely set up a vertical or multi band dipole. Actually, the biggest drawback to the software will be me learning it to teach it to him!  Hi.
  Glenn
Post by: AA6YQ on November 22, 2010, 07:59:03 PM
False: There are no secret commands; the so-called "native software" uses CAT instructions available to every transceiver control application.
Post by: W8JX on November 22, 2010, 10:29:39 PM
It is not a question of secret commands as it is user interface. The GUI can vary a lot with various packages and the GUI is what makes it pleasant or unpleasant to use.
Post by: AA6YQ on November 23, 2010, 04:26:13 PM
Your original claim was these package software setup cannot exploit the features on the radio the way native software can. Now you're changing your claim to only native software can provide a pleasant graphical user interface? Are all the pleasant GUI mechanisms locked away within the radio, inaccessible to all but native software?
        Dave, AA6YQ
Post by: W8JX on November 23, 2010, 06:55:59 PM
        Dave, AA6YQ
No not at all, example the control software for my 480 lets me control all manor of operation and even more than I can with radio directly but I have not seen another  "brand" software GUI that supports all these features and then some. So, again the GUI (Graphic User Interface) and the easy with ALL f radios features are available  and the easy with which you can access them is what brings it all together.
Post by: KB1NXE on November 24, 2010, 11:04:21 AM
Dave,
   As much as you and I have butted heads in the past, I am in complete agreement with you on this.
   To the original poster; Dave is the Author of the DX Lab Suite of software.  He is very active on the forums and is a good source to help you fulfill this requirement.
Post by: N9RO on November 24, 2010, 01:08:46 PM
I would definitely NOT use any type of Flex radio, stability and reliability would be my two major concerns.  Great software control programs are available for all radios today and since front panel knobs could be of little value I would look at something like the TS-2000B with a remote control head.  The small remote head could be mounted on the wheelchair with easy finger access; in this case I believe focus should be on what can be done via the fingers NOT the hands.  I would look into ways to not have the head tethered to the rig via wire, perhaps using one of the new IP devices?   If you decide to provide access via a mobile device then I would consider writing some simple Macro programs (no programming knowledge needed) so with one touch or click many actions would be taken.   I too am permanently disabled own both a Flex and TS-2000 and understand the frustration of not be able to simply get up walk over and plug/unplug a cable or change radios.  I use an SDR-IQ remote (although only receive) when I am wheelchair mobile in the house.  Another consideration is how well the solution works over the long term?  I think all of us with serious disabilities can tell you that for one reason or another what I can do today is not necessarily what I will be able to do next year.   I commend you on this undertaking; this is one ham radio project that can truly make a difference, improving the quality of life for someone less fortunate is a good thing.   Just my opinion for what it’s worth.
Post by: W8JX on November 24, 2010, 07:10:03 PM
I would take a long hard look at a new Kenwood TS-590 (if it is in budget) as it is a all new design and but a few months old and supports complete radio control via its built in USB port and can also send and receive audio along with control commands on that same port adding more (and easy to exploit) remote control options.
Post by: AA6YQ on November 27, 2010, 06:43:01 PM
There is no question that some transceiver control applications provide more control than others - but this is function of focus, not some proprietary exclusion as you implied in your original "these package software setup cannot exploit the features on the radio the way native software can" claim. An application focused on remote control will undoubtedly provide more control than one focused on station automation. In the remote control scenario, the developer will consume as much screen space as necessary to assure that all radio functionality is remotely accessible in a convenient, easy-to-use manner. In the station automation scenario, the developer will only consume screen space to implement radio functions in support of station automation; replicating functionality already accessible from the radio's front panel would make no sense.
In summary, whether a transceiver control application focused on remote control meets your needs has nothing to do with whether it was developed by the radio manufacturer or by an independent developer; what matters is how competently the application was designed and implemented, and how well it's being supported.
         Dave, AA6YQ
Post by: W8JX on November 29, 2010, 07:56:42 PM
To me (and maybe not you) if you cannot control all features with software package then you are not really controlling it proper. Kinda like having a car but not using AC or having a big engine and not going over 25. Why have a nice rig that software does not FULLY exploit?
Post by: AA6YQ on November 29, 2010, 11:13:46 PM
That's fine, but there is nothing that limits being able to control all of a transceiver's features to the transceiver control application provided by that transceiver's manufacturer, as you've been repeatedly claiming without substantiation. If you can't cite a concrete example of a feature that a transceiver manufacturer's software can control but independently-developed software could not possibly control, I'll consider your claim retracted.
         Dave, AA6YQ
Post by: W8JX on November 30, 2010, 09:31:23 AM
         Dave, AA6YQ
Nothing is retracted. You just do not want to "loose" so to speak but it is not about winning and loosing here. You like to make compromises to use certain products like HRD or Commander that's fine but do not suggest or promote that they fully exploit all radio remote features on all models. People come here for advise and opinions and I respect your even though I disagree, respect mine.
Post by: AA6YQ on November 30, 2010, 01:56:33 PM
Your original claim was "these package software setup cannot exploit the features on the radio the way native software can". There is nothing preventing HRD or Commander from controlling any radio feature that they don't currently control that is controlled by a manufacturer-supplied application. Despite multiple requests, you have yet to provide a counterexample that substantiates your claim that independently-developed transceiver control applications can't exploit every CAT-controllable radio feature. If you knew of such a counterexample, you'd have presented it by now. Clearly, you don't know of one; case closed.
Post by: KB1NXE on December 01, 2010, 01:36:19 PM
W8JX,
 It is important to understand there is a finite command set available on any rig.  Within the software packages identified here (DX Lab Suite and HRD), Both allow you to create buttons, sliders, controls, etc to take advantage of ANY of those commands.  Some are pre-packaged in the application by the author.  These are generally the most common functions and uses of the radio.  So, I guess this is where I do not see your point.
It is impossible for a given radio to be exploited further than the finite commands available.  If both the free packages mentioned here exploit, or possess the capability to exploit, the entire command set, then how is the 'pay for it' manufacturers software better (I use the pending release of the ICOM software here - not familiar with the Kenwood software)?
