eHam Forums => Misc => Topic started by: KC9PRE on March 16, 2011, 09:57:55 AM
Title: Is this guy nuts???
Post by: KC9PRE on March 16, 2011, 09:57:55 AM
THIS IS A New 3CX10,000A7 CONSOLE UNIT. Output power 15000+ watts 450 watts bird and 1000 peak will give you 15Kw+ RMS output and 25Kw Peak..Tube - 3CX10,000 test full power output Transmit/Receive switching 60 + Amps open Vacuum relay Power-line requirements 200/240 Vac 50/60 HZ 50+ or - Amps at 240 Vac Power Supply Heavy duty 3.5 peak amp steel core transformer and high capacitance grade filter capacitor, also features time delay starting to protect
Title: RE: Is this guy nuts???
Post by: W3LK on March 16, 2011, 10:01:34 AM
What's strange about it? It sounds like a typical RF Harris commercial HF transmitter. The Coast Guard uses a bunch of them, as do the commercial short wave broadcasters.
Post by: K6LO on March 16, 2011, 12:15:09 PM
"Output power 15000+ watts 450 watts bird..."
What are watts bird?
Post by: KE5PPH on March 16, 2011, 12:19:51 PM
:o Don't you know???? That's how much you lose, every time a bird lands on the radiating elements.
Post by: K6LO on March 16, 2011, 12:31:55 PM
Oh.  It just clicked.  The original author meant "the bird religion CB watts".   ;D
Post by: KE4DRN on March 16, 2011, 04:54:47 PM
hi
Firebird or Bird electric co meters?
Post by: NA0AA on March 17, 2011, 08:48:33 AM
ONEONEONEONEONEONEONEONEONEONEONEONEON!!!!
Post by: KC9PRE on March 17, 2011, 11:36:54 AM
Well,its not being sold to the coast guard unless a guy named Wizard has them as a customer.
Post by: W3LK on March 17, 2011, 01:13:08 PM
Where did I say it was, please? I just commented on what it likely was. Geez, we got some touchy people on this thread. Sorry I bothered.
Post by: KC9PRE on March 18, 2011, 04:10:30 AM
Your forgiven. ;D
Post by: W3LK on March 18, 2011, 08:02:05 AM
Your forgiven. ;D
That's really nice of you, since I have done nothing to be forgivern for.
Post by: KC9PRE on March 18, 2011, 09:19:51 AM
Your forgiven. ;D
Thank you!!
Post by: MAGNUM257 on March 18, 2011, 07:03:51 PM
 Where did you see this thing? Do you have a link to it?
Post by: G3RZP on March 19, 2011, 12:57:43 AM
50 amps at 240 volts is 12kW - with unity PF. So 15kW out means he really has something there!
Post by: WB6DGN on March 19, 2011, 10:26:57 PM
I'd like to see the original listing.  The posting here makes no sense at all to me.
Tom
Post by: KC9PRE on March 21, 2011, 07:14:46 AM
google wizardbuilt.com
Post by: AD4U on March 21, 2011, 11:36:08 AM
The 3CX*****A7 family of tubes (3CX10,000A7, 3CX15,000A7, and 3CX20,000A7) are air cooled triodes that can be run in the grounded grid cathode driven  configuration, similar to the more common 3CX1500A7 (8877) used in certain Alpha and Ameritron amps for example.
Assuming it is run in a properly constructed amp, a 3CX15,000A7 will deliver around 20-25KW out with 1500 watts drive.
I am not advocating this, but there are HAMs (not just CBer's) who run this much power.
Dick  AD4U
Post by: G3RZP on March 22, 2011, 09:21:38 AM
But getting that much power out of the mains on single phase is not easy....
Post by: AA4HA on March 22, 2011, 10:29:07 AM
Unless it is three phase power. I would be surprised if it was not.
Ms. Tisha Hayes
AA4HA
Post by: G3RZP on March 23, 2011, 11:12:04 AM
240 volt three phase isn't that common.
Post by: AA4HA on March 23, 2011, 11:51:39 AM
If it was a commercial radio transmitter it would be. Most of those sites bring in three phase power.
Tisha
Post by: W4PC on March 28, 2011, 06:25:26 AM
Tisha
I knew you were a broadcast engineer... it shows ;)
Post by: KG6WLS on March 28, 2011, 11:05:31 AM
Tisha
Just don't mistakingly use that stinger leg for a 120V piece of equipment. POOF...
Post by: AD4U on March 29, 2011, 09:41:53 AM
At my shop (where my main HAM shack is located) I have a 240 volt 200 amp single phase service.  From the P=EI formula 240V X 200A = 48,000 Watts.  That means I COULD run a 48,000 watt amp on my single phase service.  Granted 3 phase would be a better option, but it can be done on a single phase service.  In fact the local power company will supply up to a 400 amp (96,000 watt) residential service if needed.
Dick AD4U
Post by: G3RZP on March 30, 2011, 01:54:36 AM
Over here, single phase is not usually more than 100 amps at 220. Something that size would be run off three phase 415 volts. The HV PSU is easier on 3 phase, too.
How do they handle regulation on a 400 amp single phase supply? How close do they have the transformer?
