eHam Forums => Misc => Topic started by: FROG on December 05, 2011, 08:24:45 PM
Title: UTC time clock for computer desktop
Post by: FROG on December 05, 2011, 08:24:45 PM
 Does anyone have a link that has a UTC time clock that can be downloaded onto the desktop of a windows 7 computer. I tried one but the clock downloaded but has no min or hr hands...just a clock...I have a 64 bit operating system..I think the one I downloaded was for 32 bit..anyway would be nice to have on the desktop to view while doing contacts...
 Thanks for the help
 Frog
Title: RE: UTC time clock for computer desktop
Post by: K2OWK on December 05, 2011, 08:42:13 PM
Why not buy a large inexpensive clock and set it to UTC time. I have one in front of my transceiver that I use to record contact time. It is always there and I do not have to turn my computer on to see the UTC time. I set my clock once a week to WWV, and its keeps accurate time to +- a few seconds.
Just an opinion.
73s
K2OWK
Post by: N9BH on December 06, 2011, 05:04:22 AM
Search for Ham Clock.
It provides a window with both local time and date and GMT and date.
Post by: KG4RUL on December 06, 2011, 05:53:33 AM
I like this one: http://www.sb-software.com/nixieclock/ (http://www.sb-software.com/nixieclock/)
Post by: N7NBB on December 06, 2011, 07:29:59 AM
A clock for HAM SHACK use on the desktop is ok..  ONLY IF you have your computer set to UTC time AND date. Otherwise your logging data will be incorrect. If you don't have your computer set to UTC time and date, then I agree with a prior post of just having a separate inexpensive 24 hour battery operated clock.  Mine happens to be the "atomic" variety that receives time / date data from WWV.  My clock also displays the DATE, so just a quick glance gives accurate data for the log, Etc.  In the excitement of a rare contact, or in the heat of contest or pileup, you never have to worry about "converting" time/date in your head. There's an added benefit (?) of a ham radio conversation starter when a guest sees your "clock" on the wall and not only wonders why the 24 hour time doesn't match with "local" time, but also WHY it is a DAY OFF as well.
Hope you find your software app for your computer... I'm sure there are lots out there.
Post by: AC4RD on December 06, 2011, 09:13:14 AM
...I agree with a prior post of just having a separate inexpensive 24 hour battery operated clock.  Mine happens to be the "atomic" variety that receives time / date data from WWV.
I found accurate UTC time a problem while mobile, and I bought a $25 Casio watch to fix the problem.  Sets itself to WWVH every night, solar powered (no battery replacement needed), and with a couple of button presses, you can set it to show UTC on the main display.  I took the band off it and stuck it to my dashboard with a scrap of coax-seal.  :-)  It works so well I bought another of the exact same watch for my home station.   Very convenient!
Post by: WA2ONH on December 06, 2011, 09:38:51 AM
My desktop PC currently uses Microsoft VISTA Home Premium Edition 64-bit OS installed with SP2.
I discovered that my Task Bar adjust "DATE and TIME" function has the ability to add up to two "Additional Clocks" beyond the default LOCAL TIME clock or a total of up to three clocks.
So, I added a second "UTC Clock" that displays next to the default "Local Time" on the Task Bar.
Clock-1: (Default) LOCAL TIME = (GMT -05:00) Eastern Time (US & Canada) for QTH at SNJ.
Clock-2: (Optional) UTC CLOCK = (GMT) Coordinated Universal Time
Also, reset the "Customize Regional Options" on CONTROL PANEL for the TIME Format to display 24-Hour format versus the standard default 12-hour one.
The TASK BAR clock by default will always display the LOCAL TIME. But, you can see all clocks by clicking on or  hovering the mouse over the TIME displayed. You'll see the two clocks LOCAL TIME and UTC TIME displayed.
Take a look at these functions on your PC to see if the added options are available to you. If so, no need for additional external clock, extra software, or added cost.
Post by: K9MRD on December 06, 2011, 10:42:25 AM
I have my task bar clock set to local time and my logging program (XMLog) set to UTC date and time.  I thought all logging programs did this.
Post by: W5DQ on December 06, 2011, 11:12:16 AM
Not true. If the UTC clock app has a setup that allows the offset to be defined, the PC system clock could be set to local and the UTC app would show correct for Zulu time. Most, if not all, logging programs do this to show and record UTC time in the QSO data.
Gene W5DQ
Post by: KD8GEH on December 06, 2011, 02:49:15 PM
Win 7 32 and 64 both support the second clock option like vista. You can swap them around however you like.  I use my Ham Radio Deluxe clock and set it to UTC usually when i'm operating, logging anyhow.
Have fun & 73  De Dave KD8GEH
Post by: AB4ZT on December 06, 2011, 04:33:39 PM
I use NixClock (free), which is a pretty neat little desktop clock that looks like Nixie tubes, set to 24 hour time - it also shows seconds and will show the date if you want.
I use Dimension 4 (free) to keep the computer clock synchronized to NIST...transparent, and works well as when I compare to my "atomic clock" the Nixie is just about spot on.
Richard
Post by: KD6KWZ on December 07, 2011, 08:03:41 PM
NIST has a page about this:
http://www.nist.gov/pml/div688/grp40/its.cfm
FYI, there's this:
http://time.gov/
There are some clocks that sync with WWVB:
http://tf.nist.gov/general/pdf/2422.pdf
Post by: K9SRV on December 08, 2011, 07:24:33 PM
Check out Ham radio toolbar on Google. Cool small bar
w/ LOTS of info.
John ;)
Post by: W4XK on December 22, 2011, 06:43:41 PM
Google Alpha Clock, a neat little digital display you can put anywhere on the desktop. It displays your PC clock, and I think you can set it for a time zone different from your computer,
such as UTC. Then Google Dimension 4 V5.0. It will update your PC clock every 15 min. if you are connected to the internet. I keep a UTC display at the bottom of the desktop all the time.
Try it! You'll like it!
Bill W4XK
Post by: N6AJR on December 23, 2011, 03:29:01 PM
My normal comptuer runs local time, my logging computer runs UTC time and date with a  note on the monitor that says "this computer runs Zulu time."
Post by: KC9YZR on June 12, 2013, 08:44:03 AM
I know...this posting is a couple of years old, but I just wanted to add, in case someone else new reads this, that wants the same thing, well, I have read some of the replies, and so far there is one thing that I haven't noticed, and that is, This PC came with WIN-Vista, but I have installed a 64-bit Windows 7 on it, and it has clocks, as gadgets, and I have a UTC clock set up to the right side of the screen, as a gadget, and if you do not show any gadgets onscreen, just right click and choose "Gadgets," and then the gadget box will show up and then you can drag a clock over to the right side of the screen, then hovering the cursor over the clock, to the upper right of the clock you will see a wrench, click on that, then click on the down arrow by where it says, "Time zone:," and scroll up to the top of the list and choose whichever one is the right choice for you, for me it was "International Date Line West," then you can choose 1 of 8 different clocks, but they all look analog no digital choices, and you can also name the clock and also choose whether to show a second hand or not. Maybe this is way too late for you but maybe someone else "new" might be able to use this info...Have a nice day...By the way you can also add a calendar and weather gadgets to the gadget area. Wish I was here two years ago, to reply, but I gave up Ham Radio for more than 12 years, but have decided to get back into it....LOL
