eHam Forums => CW => Topic started by: GABRESEVEN on June 06, 2012, 06:23:41 PM
Title: CW Decode Software
Post by: GABRESEVEN on June 06, 2012, 06:23:41 PM
Any suggestion for CW decode software? I just want to monitor CW (ham and maritime)...
Something I can install and monitor CW with my laptop, that's easy to use, plug & play...
GABRESEVEN
Title: RE: CW Decode Software
Post by: VA7CPC on June 06, 2012, 08:21:01 PM
CW Get:
http://www.dxsoft.com/en/products/cwget/
As I remember, the "free" version is full-featured, and will occasionally nag you.   When I realized that it was an integral part of my station, I paid for it.
It'll work fine with strong CW signals, with properly-formed characters.  Don't expect miracles -- it's not nearly as good as a good pair of ears.
          Charles
PS -- you can also use the CW decoding software in "multi-use" packages like Ham Radio Deluxe / DM780, or "fldigi".  But CW Get works well enough for me, and it's way simpler that the other packages I listed.
Post by: KF4O on June 07, 2012, 01:08:09 AM
CW Get is good, but there is also
Fldigi
http://www.w1hkj.com/Fldigi.html
and CW Decoder
http://www.amqrp.org/projects/cwdecod/decoder.htm
try them all!
Let us know which one you pick.
Randy, KF4O
Post by: AE4RV on June 07, 2012, 12:17:05 PM
Let us know if you find any interesting code in the maritime bands.
Post by: K0CBA on June 12, 2012, 08:07:31 AM
The best 'decoder' going is between your ears.
Post by: WY4J on July 03, 2012, 12:26:54 PM
Never seen one that works 100% unless is machine sent but your brain will copy under any and all conditions.
Post by: KK0G on July 03, 2012, 01:38:37 PM
I have to agree, most of them suck at copying unless it's a strong signal and near perfectly sent code. Just learn the code, trust me, it's not that difficult.
Post by: W4AUE on July 24, 2012, 07:29:58 AM
The auto decoders work pretty well with machine sent code, but not with the average operator sent code.  FLDIGI seems to work better than the others I've tried - free.  Also includes other digital modes.
Over time you will learn to recognize the operator by the "swing" in his fist ... now you're having fun!!
Post by: PA0BLAH on July 24, 2012, 08:37:26 AM
That "the brain will copy under any and all" is certainly and proven not true.
I made with a microcontroller a decoder for www.rufzxp.net It decodes easily the max speed, (abt 800 wpm) I can't and will never be able, I am sure,  and I am a QRQ plain text rag chewing guy.
The decoders are a crutch for the no code guys, and can help to increase your proficiency.
Post by: WB3CQM on July 24, 2012, 04:42:02 PM
http://www.dxzone.com/cgi-bin/dir/jump2.cgi?ID=6642
MRP40 Morse Code Decoder & Sender
Most likely this is the Best of the Best ? IMHO
73 JIM
Post by: PA0WV on July 28, 2012, 02:53:11 PM
73 JIM
Don't know, I never buy commercial equipment, because it kills ones creativity.
The starter asked about software, not about hardware decoders.
I designed and build 2 different hardware decoders, you can find them on my website
http://pa0wv.home.xs4all.nl/zelfbouw.html first two links from top of page.
The detection is by a touchtone decoder phase locked loop, as first published by IK3OIL.
There are (in the link TIMorsedecoder) testfiles wav format Morse1 through Morse5. Morse 4 and 5 are copied solid, Morse1 through Morse3 not. So one can find out, and decide for yourself,  what the performance of those decoders is.
Edit: I understand that you meant software. With the mentioned wav files you can test that software.
Post by: VK5DO on July 28, 2012, 05:49:08 PM
I'm, interested in having a look but ich spreche nicht Deutsch.  Is there an english version?
Dene
Post by: PA0WV on July 28, 2012, 11:44:06 PM
Dene
Sri, no, but the point is that you can listen to the files Morse1.wav through Morse5.wav . Morse4 and Morse5 are 100% decodeble; 1 through 3 are not. So it is possible to compare with those short testfiles other decoding devices of software.
Post by: K3DCW on July 30, 2012, 06:40:44 AM
73 JIM
Another vote here for MRP40.  Works great on all but the absolute worst fists.
Dave
K3DCW
Post by: KK4CPH on August 04, 2012, 03:09:57 PM
Don't know what you're running on your laptop but CWdecoder says it works on Windows 95/98 and MRP40 works on Win 95 up to XP.
FLdigi works on Windows, Mac, and Linux.  I can't speak for the other programs, but I'm using FLdigi and tried listening in on CW and IMHO it seems to work great unless there's a lot of QRM/QSB.  And if there's 2 stations right next to each other, you can click on the waterfall and copy either one.  Whichever you choose... enjoy!
Eric
Post by: WF7BSR on September 18, 2012, 04:06:51 AM
How do these programs work with Windows 7?
Thank you for your time and assistance,
Raymond
