eHam Forums => VHF / UHF => Topic started by: N0SOY on August 29, 2012, 04:23:44 PM
Title: What is a "birdie"
Post by: N0SOY on August 29, 2012, 04:23:44 PM
I have a MFJ9406 and I was running a receive only test on 6m with a 10m antenna (My 6m had not arrived ) I kept hitting points where there bfo screamed but there was not any voice on it.  I suspected that it was just a weak signal that I could not lock on to but I wonder if anything else was happening. Or if the radio needs a re-alinement.
Title: RE: What is a "birdie"
Post by: NO2A on August 29, 2012, 06:01:03 PM
Birdies are generated by the rig itself. I doubt an alignment would make any difference. Some rigs have many,others hardly any.
Post by: KM3F on August 29, 2012, 09:58:16 PM
Two oscillator signals or harmonics mix together within the radio and are detected by the audio detector same as a normal signal would be.
If the sleight difference in frequency or F1 +/- F2 between them is in the audio range, you can hear it.
Good receiver designs place this issue outside the bands your use so you don't hear them.
Good luck.
Post by: KA4POL on August 30, 2012, 07:45:04 AM
Besides being a result of mixing frequencies it is also possible to receive harmonics of internal oscillators. You should see what frequencies you are receiving those signals on. It may well be the case you are receiving DSL signals or something similar as well. An alignment will shift those signals at best.
Post by: AA4PB on August 30, 2012, 08:20:03 AM
If its a "birdie" then its internally generated and you will still hear it with the antenna disconnected. If it goes away when you disconnect the antenna then its an external signal rather than a "birdie" and it'll have to be eliminated at the source.
Post by: N0SOY on August 30, 2012, 10:33:52 AM
Here is an update.  Last night I hook up the power and turned on the radio with no antenna.  No bfo activity but when an antenna was hooked up it the bfo activated on 50.125 and various spots.  I suspect that the radio was picking up weak signals that were not audible but the bfo responded.  ( I am not sure what the correct term actually is. )
Best
David
Post by: KA4POL on August 30, 2012, 10:50:08 AM
A beat frequency oscillator or BFO is a dedicated oscillator for creating an audio frequency signal from Morse code or an intelligible signal from a SSB carrier.
You were obviously receiving some such carrier from outside. There can be lots of sources in your house or in the neighborhood. I can for example see my DSL signals.
Post by: WB8VLC on August 30, 2012, 11:53:40 AM
Your lucky you only have one at 50.125 MHz How about a list of products that cause birdies on all of my 6 meter radios from 50.000 to over 53 Mhz.
1.Black and Decker coffee maker.  Fixed by wrapping cord with ferrite chokes.
2.Netgear Router.  Fix: Replaced wall wart power supply with a home brew linear regulator.
3.CFL lamps.  Fix: tossed all CFL's out and purchased a good supply of incandescent bulbs.
4.Cable TV leakage.  Fix: Removed all of the unconnected cutoff cables handging off of the entry panel and terminated all of the connected but unused ones.
5.Electric lawn mower pulse charger.  Fix: a nice old gas mower as a replacement works wonders.
6.Electric Leaf blower charger, (The green people can toss their electric gas replacements in the garbage as far as I'm concerned)  Fix: used the internal battery for another project and I smashed and tossed the electric leaf blower in the garbage. I can honestly say that it was an exhilerating feeling smashing this junk device with a sledge hammer.
7.Neighbors plasma TV. Fix: 6 meter band modified MFJ 1026 nulling box. This device worked so well that I can now hear and work Europe on a small 5 element yagi during those rare band openings.
8.Street light a half block away with faulty photocell that local Power company hasn't fixed yet.  Fix: keep bugging portland electric to fix this wonderfully designed piece of art ( sarcasim).
good luck with your noise
Mike
Post by: W5DQ on September 07, 2012, 01:53:50 PM
One under PAR at most fairways  ;D
Seriouslythough, it is an internally generated carrier that is found by the RX circuitry. They can be most annoying if there is one on a freq you want to operate because basically without redesigning the radio, they cannot be removed.
Don't misinterpret a externally generated RFI signal as a birdie. Many RFI signals will disappear when the antenna port is connected to a dummy load. A 'birdie' will not disappear. In fact, it may sound louder due to the loss of background noise compared to when the actual antenna is connected.
Another difference is you like them in golf and hate them in ham radio!!!
Gene W5DQ
Post by: KA4POL on September 07, 2012, 09:48:47 PM
Golf is a game whose aim is to hit a very small ball into an even smaller hole, with weapons singularly ill-designed for the purpose (Winston Churchill)
That's why we stick to ham radio.
Post by: W5DQ on September 08, 2012, 01:29:58 PM
Golf, like ham radio, is a pursuit to improve one's abilities. Anyone with minimal coordination and enough attempts can put a golf ball in the cup as well make a QSO. The trick to both is to do be able to do it effectively, when you need to, sometimes under adverse conditions.
I always like the statements made by non-golfer's about how silly and archaic the game of golf is. Golf is one of the oldest organized sports known and it takes some perseverance to get to be good at it, just like ham radio.
I like both although I will admit. I am much better at ham radio operating than I am at golf.  ;D
Gene W5DQ
Post by: AA4PB on September 08, 2012, 02:56:26 PM
Is a QRP golfer one who insists on using a short club?
Post by: KA4POL on September 08, 2012, 11:24:26 PM
Actually Churchill did play golf in his younger years. He, however, preferred to play polo which suited him better: live opposition, a much bigger ball.
By the way, golf started out from Scotland.
Post by: N0SOY on September 09, 2012, 09:30:54 PM
Yes the Scotsmen who invented it must have been really wasted and thought it was funny at the time.
Think about it, knock a small ball into a goffer hold with a bent stick.  Add to it put the hole a long way away.
Post by: W5DQ on September 10, 2012, 08:42:21 AM
Nothing that a steady intake of alcohol won't make appear to be easier than it is :)
Gene W5DQ
Post by: WB6DGN on September 21, 2012, 12:55:38 AM
What is a "birdie"
1.  A two legged critter with wings and feathers instead of hair covering their bodies and having a beak instead of a mouth.  Often able to fly under their own power.  Frequently travel in "flocks" during which time those on the ground are advised to carry umbrellas.  OR
2.  A hand signal usually indicating intense disapproval of a person and/or their activities.  Frequently seen on the road, particularly during highly congested traffic conditions.
Post by: K9MHZ on December 12, 2012, 05:23:28 AM
I remember new solid state gear.....maybe mid 1980s or so, was FULL of birdies. That's one reason I get uneasy about new hams going for gear of that era to get started in the hobby.  Some will tout the greatness of particular models of that time frame, but for a few $hundred more, a new ham can get a great modern rig......they're much, much better radios today.
Post by: N0SOY on December 21, 2012, 09:29:01 PM
What is a "birdie"
Oh that's what that means.  I thought it was have a nice day.   ;D ;D
Post by: WB6DGN on December 24, 2012, 10:12:17 PM
I suppose it could mean that depending on the gender of the person "sending" it!
I like your callsign, Mr. "I don't know"  (No soy)  Do you get many comments on it?
Tom
Post by: W9FIB on December 25, 2012, 04:29:13 AM
Hi David,
My key observation from what you posted was that the birdies appeared when you hooked up the antenna. It sounds like QRM getting into the radio. I have the same problem with both old and new rigs. But I know where mine comes from. 90% come from my computers and my network that links them. 10% come from outside sources.
Anything that uses electricity can in some way make noise in the radio spectrum. The problem is tracing down what device is making the noise, and then fixing it. Like another said, could be your stuff, could be a neighbor's stuff, power company stuff, cable TV stuff, a close by factory stuff, etc. The list is almost endless.
The first thing I would do since you are making a new installation, is use the "best" coax you can afford with as few as possible connectors between the antenna and the radio.
Stan
Post by: N0SOY on December 26, 2012, 06:43:07 PM
It appears to be the wifi router. At least that is the main ones.  I turned off the router and they stopped.
Thanks
Post by: N0SOY on December 26, 2012, 06:44:12 PM
Tom
Good point
Yes, I get an occasional comment it is easy to remember.
Post by: K1CJS on December 27, 2012, 04:52:02 AM
Whoops!  Sorry.  Duplicated someone elses reply.
Post by: K4JJL on January 07, 2013, 10:41:31 AM
Tom
Good point
"Yo no soy" means "I am not".  "I don't know" is "Yo no sé".  Been living in Miami too long...
Post by: WB6DGN on January 09, 2013, 08:33:08 PM
And I guess I've been away from California too long!  Or...that's what you get when you learn the language in a Mexican restaurant!  Maybe a little of both?
Tom
