eHam Forums => VHF / UHF => Topic started by: KE1JR on September 30, 2012, 06:24:22 AM
Title: IDing and talking to people, new to VHF
Post by: KE1JR on September 30, 2012, 06:24:22 AM
I'm new to VHF, I put a radio in the car with a 1/4 wave on the roof a few weeks ago but have been unable to talk to anyone yet.
Programmed in two of the most active repeaters, I transmit and say my call sign or my call sign and listening but no one ever responds. A while later I'll hear people talking to each other, should I say something else to get people to respond to my call? Maybe they don't want to talk to me because I'm a stranger?
I did manage to talk to someone on 146.52 from home once, it was an airplane, which was exciting and a little pile up formed. I could hear some of the other ground stations but when I call CQ on 52 no one has ever responded, is this normal?
Last question, am I required to say the other stations call letters? When at home I use a pen and paper to take notes then log the QSO later but when driving I can't remember the other stations calls, they say the letters too fast or I'm worried I'll jumble up the letters, maybe my short term memory isn't very good. In any case is acceptable to just ask for their name, use their name when addressing them and then say my own call letters once every 10 minutes and when signing off? I believe that's all that's required by FCC but when I listen to the repeaters most everyone says the calls of the other stations.
Thanks for any feed back
Dave
Title: RE: IDing and talking to people, new to VHF
Post by: KA4POL on September 30, 2012, 07:12:30 AM
Your experience is not extraordinary at all.
Just call CQ via whatever repeater you are using. This will tell people you are looking for contact. You might ask for a report declaring you are testing your rig. Nasty way, but works. Some people seem to be shy of strangers and only talk to those they know from past contacts. But one has to start somehow.
.52 is the simplex frequency, keep on trying. You got a 1/4 wave antenna which does not really give much performance.
You got to identify yourself. Mentioning the other station is not mandatory. It helps, however, if there are others, so you identify the one whose turn it is.
Of course it is acceptable to ask for the handle. And if you didn't get the call sign or name just ask to say again. I think almost every ham knows there are always possible problems in understanding. First thing is you are driving a car safely. Then there is the radio.
Don't give up, all those on the band didn't.
Post by: K0ECW on September 30, 2012, 11:27:46 AM
Definately ask for a signal report on the repeaters.
Make sure that those repeaters don't require a tone. Make sure you have the right tone. It wouldn't be the first time that the repeater book conflicts with reality.
If you have another VHF radio use it to monitor and make sure your transmissions are actually going through the repeater.
Don't worry if you can't remember the other guy's call, as long as you remember your own (hi hi) you'll be fine.
It is very normal, if depressing, to get no response on 146.52. Keep trying. A lot of people monitor 146.52 while traveling but wait for someone else to talk first. Try IDing every 10 miles or so and see what happens.
Part 97.119 Station Identification only requires that you identify YOUR station every 10 minutes while conversing and at the end of the conversation.
Post by: KE1JR on September 30, 2012, 11:42:27 AM
I had .52 on most of today, silent for hours then I heard someone calling CQ SODA CQ SODA, I thought he was thirsty, but turns out he was saying CQ SOTA and was on small mountain about 40 miles away.
I worked him and I heard him pick up a few other people, some of which I could also hear so there is activity out there. Feeling better about this already.
I'll try asking for a signal report tomorrow on the repeater while driving to work and see what happen.
Thanks
Post by: KA4POL on September 30, 2012, 11:52:46 AM
You see, you are already gaining experience. May be you should drive up that hill to have better chances for finding other stations.
Post by: WN2C on September 30, 2012, 12:24:30 PM
Find out if there are any nets on your local repeaters and check into them. You will start to be known and sure to make some new friends on the air.
73 and good luck
de wn2c Rick
Post by: KQ6EA on September 30, 2012, 02:07:02 PM
Guess I'm old fashioned, but calling CQ on a repeater is/was considered very bad 'Radio Etiquette'.
As somebody else said, just key-up the repeater and ask for a radio check.
Jim
Post by: AG6WT on September 30, 2012, 02:46:05 PM
Dave,
Do those repeaters give you a courtesy tone after you unkey the mic? If you don't get one but you hear one when others are talking, you either have the wrong tone programmed or tones turned off.
If you are getting into the repeater, id yourself and ask for an audio report. Around here, at least, that will bring out at least one person who is just monitoring when all is quiet.
Good luck,
Ray KJ6AMF
Post by: KC9NVP on September 30, 2012, 03:58:19 PM
I agree with Ray, check your radio manual on programming in the PL tone, and maybe the sub audible tone as well.  Where I am at in northern IL, the repeater I use has the same input/output freq as two other repeaters 90 miles away in opposite directions so having the sub audible tone turned on helps to cut down on transmissions from these two setting off the radio.
I hate to say it but when I had my first radio, I programmed in the repeater input/output freq but forgot to set the tones and like you wonder why I was not making any contact except on simplex.
Check the radio manual and see if you have additional programming to do.
Good Luck,
73, David
Post by: AA4PB on September 30, 2012, 04:23:10 PM
Jim
I guess I'm older fashioned than you because back when repeaters were first being used we called CQ all the time. The issue is to do a very short CQ, a 1X1, (CQ this is AA4PB). Why would a simple CQ to clearly indicate that you want a QSO with someone be "bad manners" while "AA4PB listening" (listening for what?) or asking for a "radio test" when you really want a QSO is not?
Bob
Post by: N5TWB on September 30, 2012, 05:42:29 PM
You've been a ham for 15 years so I know you're aware of clubs in your area, some of whom probably support the repeaters you are monitoring. I'd suggest joining one of those clubs to form some in-person connections that would then support interaction through the repeater. You would be a great resource for a club with your experience in IT and kit building. Those clubs probably are involved in some community service events with their repeaters and that could add to your in-person relationships for future radio contacts.
Post by: KE4VVF on September 30, 2012, 10:57:06 PM
Your story is similar to others.  It is difficult to get contacts on repeaters if you are "unknown" to the community.
My solution to the same problem was to check into all the local 2 meter nets, stick around and rag chew during the informal portion; then I joined the largest Amateur Radio club in my area.   Rag chewing shows your character to the community and generally assures them that you are not a mass murdering, Satan worshiping, axe wielding, drug crazed arsonist and mixing with the local folks face to face at meetings allays any fears that you may have multiple heads with horns.
It also helps immensely if you volunteer to work a shift at the Ham Fest and/or become an alternate Net Control Operator, but that can wait until they actually talk to you.
In regard to 146.520, unless you have a 10' to 12' Yagi or you live on a mountain, contacts on that freq are always rather spotty. I have excellent antennas and only hear activity there every few weeks.
I do recommend that you scan all the 2 meter Simplex frequencies and not just the call freq because ~90% of 2 meter FM Simplex occurs there. 147.505, 147.555 and 146.550 are the most popular in my area, I'm sure it's different where you live.
Post by: KE1JR on October 01, 2012, 08:15:55 AM
Found the website of the closest club, about 25 miles away, and they have a net each night and a monthly meeting. I listened last night, I'll try checking in. They check in so fast there is hardly a space to get in, worried I'll double key someone. They also have a monthly meeting, thinking about going and introducing myself. My PL is set correctly, I do hear the beep and carrier from the repeater when I've tried giving my call.
I became a ham 15 years ago when I was 14 then mostly lost interest when I started college and got an internet connection but have renewed my interest in radio recently. I've had a couple of false starts, I get really into it then lose interest after 6 months and a few dozen contacts. I have a case of mic fright and mostly stick to keyboard digital modes on HF but chatting with macros gets boring after a while, thinking about trying cw but not sure my skills are good enough. Would like to use voice more but I feel self conscious about speaking at home, don't want my voice traveling through the walls and getting complaints to keep quiet which is why I've stayed with keyboard mode which I can do in the evening without disturbing anyone.
Trying to find a mode I enjoy, giving VHF a try because it's something I can do while commuting, the antenna is small, and I'm alone in the car so no one will give me grief for making noise. I thought about putting a 10 meter in the car but decided to try VHF first because of the smaller antenna, if you had to pick would you rather a 10 meter or a 2 meter in the car for making casual contacts? Solar cycle seems good right now, a lot of activity when I get home from work and on the weekends but it fades fast as the sun goes down.
Thanks for the tips and encouragement, I'll be more persistent putting my call out there and giving VHF a try.
Post by: AG6WT on October 01, 2012, 08:17:47 AM
Dave,
Good luck,
Ray KJ6AMF
I forgot to mention you should also check your repeater shift. Modern rigs have an automatic shift feature so that it will transmit on the correct input frequency but usually you have to enable it. If it's disabled or if the repeaters use a non-standard shift, you'll never get into the repeater even with the right PL tone but you will hear other people talking on the output frequency.
Post by: AG6WT on October 01, 2012, 08:22:46 AM
Dave,
Unless it's a private, exclusive club, net control should call for guests and visitor sometime during the net so you can try to check in then.
Another thing to try is 5-10 minutes before the net, call out for a radio/audio check. You'll have the most people monitoring then and at least one friendly soul should get back to you.
Ray
Post by: KE1JR on October 02, 2012, 04:56:26 AM
I checked into the net last night, net controller was nice and I was welcomed in, he even invited me to run the net in the future if I wanted, my fear was for naught. Hopefully I'll be able to make some friends on the radio and maybe at the club.  Thanks.
Post by: N5TWB on October 02, 2012, 02:00:08 PM
Good job - as a 1x/month ARES net controller, I know I always appreciate new check-ins. Let us know how it goes after a visit to the club meeting, too.
Post by: N0FPE on October 07, 2012, 07:20:51 AM
Shovels have handles...people have names
Post by: KK4IKO on October 16, 2012, 03:17:10 AM
I never found that folks were unwilling to talk if they were on the air. but being polite and waiting for a break to say your call sign is important.
The first time I got my new license on the air (last May), I was tuning through the VHF band when I stumbled upon several folks ragchewing.  I listened until there was a break, gave my callsign, and found I was covered up with people wanting to chat.  I explained I was a newbie, so they were patient with me.  I asked where they calling from, and discovered I was on a repeater 80 miles from my location.  I was located at 5500' with a clear shot in that direction.  I figured a first contact might be easier from a high vantage point.  Interestingly, the local repeater, 3 miles away and higher still, was as silent as a tomb.
I live in the mountains of western North Carolina, so hooking into the various repeaters can be a challenge, sometimes.  A half mile change in location, or a few hundred feet elevation makes all the difference.
In a couple weeks, I'm taking part with my local club in a Race Net.  It's a 16 mile mini marathon (all uphill).  It will be an interesting experience.
Bruce, KK4IKO
