eHam Forums => Software Defined Radio => Topic started by: W8KQE on January 10, 2013, 01:31:17 PM
Title: Any decent inexpensive SDR shortwave receivers out there ($300 and under)?
Post by: W8KQE on January 10, 2013, 01:31:17 PM
I'm a newbie at SDR here. Are there any basic, simple SDR shortwave receivers out there?  I'm thinking of purchasing the Sangean 909X shortwave receiver, but then got to thinking, it would be cool if there were a decent SDR type radio for a couple of hundred dollars I could try instead (just to try my hand at SDR technology).  Thanks.
Title: RE: Any decent inexpensive SDR shortwave receivers out there ($300 and under)?
Post by: KN0CK on January 10, 2013, 04:05:30 PM
One that's becoming more popular as a 'casual listening' SDR is the RTL-2832 DVB-T USB stick receiver and the 'Ham-it-Up' HF upconverter board, using HDSDR to tune the DVB-T receiver.  The cost for both of those are: DVB-T USB Receiver = $18.00, 'Ham-it-Up' HF Upconverter = $49.00....So together they won't break the bank and can be powered from a USB port.   I started out using one of those purely to see how well it performed and was pleasantly surprised at how well it receives in the HF Ham bands and SWL frequencies.  It's not a high performance radio (doesn't have wide dynamic range like the better SDRs out there), but for what you get it's a pretty nice combo and makes an easy receiver for HF for casual listening and it won't break your wallet.  Does great on the SWL bands because of the strong signals (what's left of 'em).  Compact, too - - my first setup was contained in a 2" x 6" x 4" plastic case from Radio Shack, and my second setup is contained to about the same 'footprint' of the USB DVB-T receiver (0.75" x 2.75" x 1.0")
There's also another thread out here on EHam (http://www.eham.net/ehamforum/smf/index.php/topic,82601.45.html) where I've built my own HF upconverter from common parts you can buy from Digikey and make a little better performance HF upconverter for about the same money as the DVB-T receiver (about $18.00).  The HF upconverter I built I'm redesigning to fit into the DVB-T receiver case, too - you'd never know there's an HF upconverter in it, but will be a totally self-contained HF receiver USB stick.  Check out the thread for more details if you're interested.
TNX & 73 de Marty, KN0CK
Post by: KA4POL on January 10, 2013, 10:02:07 PM
SDR is a very interesting area. There are some commercial receivers out on the market. They are higher priced than your tag of $ 300. Looking at short wave it is easier to cover frequency wise.
For your price limit you would have to consider getting a kit to assemble yourself. May be you have the experience. Then this could be great fun.
As Marty mentioned there is another possibility in the thread I started some time ago. But this involves also a tiny bit of homebrewing for shortwave reception. It is also described in the January QST.
Now you mentioned the word 'decent'. The question is what do you regard as decent. Many people are happy with a DVB-T stick some others rather want to play the higher end. I think there is no real mid range of quality to be found for commercial SDR receivers.
Depending upon your capabilities I would give it a try with the simple solution. You don't lose much money.
Post by: K5TED on January 11, 2013, 09:40:18 PM
The Lazy Dog LD-1C is in your price range.
My suggestion to you, if you are looking for a good communications grade SDR, is save up another $150 and find a good used Flex 1500. You won't be disappointed.
Post by: WD5GWY on January 12, 2013, 08:53:43 AM
I agree with TED, if you can save up a bit more and pick up a used Flex 1500
you will get a much better receiver(and transmitter too).
I have one of the dongles and Ham It Up converters here to play with and while
it works better than I expected, it is not in the same class as the 1500. (as a receiver)
The dongle/upconverter setups are fun to play with, but, for some serious Shortwave
listening, the 1500 is a better deal.
james
WD5GWY
Post by: W0NTS on January 18, 2013, 05:18:56 AM
Add a few more dollars and get a Ten Tec RX-320D. I recently purchased (2) used Ten Tec transceivers. The receivers of both are terrific. That led me to purchase a demo RX-320D from Ten-Tec which will arrive today. Reviews give the RX-320D very high marks. The biggest gripe concerns the control software for the radio. Comments indicate better performance can be obtained using other control software, some of which is freeware. The Ten Tec salesman that took my order informed me they usually have demo units on hand at a reduced price. They have the same warranty as a new unit.  Dennis  W0NTS
Post by: NK2F on January 18, 2013, 06:59:28 PM
Afedri for under $300 delivered.
Post by: WV4I on January 25, 2013, 07:46:26 AM
Softrock Receive Ensemble II, HF or LF. $67 kit, $109 assembled on Ebay. Also a 2M version out there. Need USB, sound card with stereo input, 12VDC supply, and antenna. If used near a transmitter, a front end protector of some sort highly recommended, even with an ext T/R relay. Works with SDR#, SD-Radio software, more.
Installing the USB driver for SDR's can be a bit tricky. Some look like a HID to Win OS, so may have to get PC running, install driver with Softrock disconnected, then disconnect all other USB, connect Softrock. Lots more info on Softrock Yahoo group.
Post by: W0VP on January 26, 2013, 04:52:04 AM
I've been looking at SDR options for a little over a year and considered a few dedicated SDRs (Ensemble II, FiFi SDR) along with some of the more expensive radios (Ten-Tec RX-320D), but after reading the article in last month's QST I decided to test the waters with the DVB-T Dongle + Ham It Up converter, and it has been a lot of fun.
One option that hasn't been mentioned to you yet, and is the least expensive at free, is websdr.org. It is a network of SDR receivers connected to the internet. You download the software, connect to a receiver, and then you can do just about anything you could with your own SDR receiver. It's pretty cool and there are receivers located all over the world.
Good luck and have fun!
KC, W0VP
Post by: KK4MRN on January 27, 2013, 10:09:34 AM
Another poster mentioned SoftRock SDR.
http://fivedash.com/
The cheapest is the SoftRock Lite II Combined Kit for US$21, but you have to build it yourself.  I do have a question about this.  Are there any surface mounted parts I must solder myself?  If yes, then this kit is a no-go for me.    Once built, does it need test equipment to align it? I do not have any test equipment.
There is the Built SoftRock Ensemble II HF Receiver for $92.
If you go to www.websdr.org and go to w4ax, they use the SoftRock SDR receivers.  So, I am impressed how well they work.  Then again, I am no ham radio expert.  Most likely the antennas are good.
Post by: NH7L on February 14, 2013, 11:14:46 PM
Besides the digital TV dongle approach, with an upconverter to get you HF bands, google the Funcube Dongle Pro+. It's just under $200 delivered in the U.S. Needs no upconverter because it covers LF, MW, HF and all the way up to 1.9 or 2 GHz, with a gap of about 200 MHz above about 240 MHz. The original Funcube Dongle was designed to receive only the Funcube ham satellites, for school kids. Then came the Funcube Dongle Pro, which covered a much wider frequency spread, but not including HF and below. The Pro+ came out a few months ago. I've had one delivered to my U.S. address and will begin fooling with it shortly. Plan to run it on Windows-equipped Macs with free SDR# software. The Funcube Dongle Pro+ sells out as fast as more become available. Best way to get one  is to put yourself on the waiting list for the next batch. Designed and manufactured in the UK. Also sold in limited quantities by a few UK ham stores, occasionally used on eBay and elsewhere.
Post by: N5RWJ on February 15, 2013, 10:11:44 AM
Check out the SWL topic on this forum.
Post by: SWL535 on February 17, 2013, 10:19:16 AM
The little FiFi SDR will set you back about $175 by the time it lands on your
doorstep. There is a free GUI from Bonito just for the FiFi.
http://www.box73.de/product_info.php?products_id=2425
Ken
Post by: AB2YC on February 18, 2013, 01:48:53 PM
I build one up last month and it is a nice little radio
Post by: AG6PO on February 22, 2013, 01:47:49 AM
I have the Afedri SDR Net receiver. 1.25MHz of bandwidth can be received at any point in the range from 100kHz to 30MHz. It works with Linrad, Winrad, HDSDR, Studio1, SDR#, SDR Console, SDR-radio, and CuteSDR as well as others with a bit of work. It can work independently connected via Ethernet or directly connected via USB (only 250KHz of receive bandwidth).
It's well built, the designer is actively supporting it, and there's a good community on a Yahoo Group.
Cost: $250 with a case, $200 without.
Post by: KB9VGE on March 19, 2013, 07:56:03 AM
Add a few more dollars and get a Ten Tec RX-320D. I recently purchased (2) used Ten Tec transceivers. The receivers of both are terrific. That led me to purchase a demo RX-320D from Ten-Tec which will arrive today. Reviews give the RX-320D very high marks. The biggest gripe concerns the control software for the radio. Comments indicate better performance can be obtained using other control software, some of which is freeware. .... W0NTS
* I have one and love it, but its NOT an SDR radio.
* Yes, there's a lot of 3rd party software, but none of them will change the performance; they just vary in terms of convenience feartures and usability.
* The 320 !!BADLY!! needs to be updated to accomodate a higher speed USB connection
Post by: KA4NMA on March 19, 2013, 06:28:10 PM
Marty,
I am interested in your hf upconverter and dvb dongle.  How can I get in touch with you?
Randy ka4nma
Post by: NI0Z on March 19, 2013, 07:05:33 PM
These are quite nice, a little over your price tag, however you can expand by adding and AMP for transmit, then go later with a TenTec amp to get to 100 Watts.. Ect.
http://www.greenmountainradio.com/G11/order.html
Check them out!
Post by: VE2AHI on March 21, 2013, 10:44:26 AM
I'm also ready to recommend the AFEDRI SDR-Net.
Although I have fun with the (3) Softrock kits I've done, the ease of putting the AFEDRI on the home network and then tuning in from whatever computer I'm in front of is a plus. Different software packages allow me to experiment. The radio works well, and the shipment by 4Z5LV was rapid.
There's an active support group on Yahoo, as well. All in all, a great product, from where I sit.
Gord VE2AHI
Post by: KS4JU on March 21, 2013, 02:34:19 PM
Ham Radio Science did a quick user review on the Afedri. Nice little HF SDR for the money.
http://www.hamradioscience.com/afedri-sdr-net-2-3a-review/
Post by: WX2S on March 22, 2013, 12:21:08 PM
I'm in the process of building one of these now to use as an IF skimmer. You do have to solder SMDs, which is tedious and error-prone compared to old-style Heathkits. I've spent hours trying to find one solder bridge that was causing a low-voltage problem, and I'm still not 100% sure I've found it.  :-[  >:(
There is no "alignment" as such. A good multimeter is a must; a scope and a signal generator are helpful but not vital. You will also need a good soldering iron and 63/37 eutectic solder, a Panavise or similar, and a magnifying lamp or head-mounted magnifier.
Be aware that the Softrock Lite II will tune only one band, or part of one.
- WX2S
Post by: KH2BR on April 05, 2013, 10:44:46 PM
I use the FIFI every day and love it. Its used with SDR-Radio software.  It has a band switching band pass filter in it and also its own dedicated dsp sound card on board plus you can use the sound card in the computer if you want. I use it as a external SDR receiver along with the icom IC-7600. Point and click on a signat and the radio goes there. ,, So cool, I would be at a loss with out it.
Post by: KD7RDZI2 on April 20, 2013, 09:52:27 AM
for a budget of 300USD go to http://fivedash.com and ask for the "BUILT RX ensemble II" and... give me 200 ;D
Post by: WB8NUT on April 24, 2013, 09:16:39 AM
I ordered a Funcube Pro+ SDR from Martin Lynch in the U.K. a few weeks ago. Cost me about $205.00 delivered.
This thing is amazing. From below the AM broadcast band to almost 2Ghz.
Many different SDR applications support it so you have your choice. Unlike many SDR receivers out there, you have LW, MW, SW, VHF, UHF and SHF.
I am having a ball with this little thing. Really worth it.
Post by: W7SMJ on April 24, 2013, 12:12:01 PM
The Funcube Pro+ looks intriguing, but I haven't seen anything published regarding the Dynamic Range, only that it's improved over the last version.  Have you seen any issues with front end overloading?  Are you in an urban or rural environment?
Thanks and 73,
Scott
Post by: KD7RDZI2 on May 16, 2013, 01:21:12 PM
detract more than 200 bucks and have a Built RX Ensemble II from http://fivedash.com/. The Ensemble II is based on the soundcard, which must have a stereo line input and be preferably 16bit or better. Using SDR# gives quite impressive results in terms of image rejection, dynamic range and sensitivity even using a non expensive soundcard. The last but not the least, learning curve is very fast, there are NOT 300 boring pages in the user manual to understand... just plug and play!
