Author Topic: Arduino "Group" ????  (Read 90156 times)
KT4WO
« on: February 04, 2015, 11:01:48 AM »
Looking for something like a Arduino yahoo group or Google group.
Help??
I need help learning some code.
Trip - KT4WO
PS---I have a UNO hooked to a AS3935 lightning detector board...its working(I guess??!!??...no storms yet)
but would like to add some code to trigger a relay when it detects lightning.
KT4WO
« Reply #1 on: February 04, 2015, 01:14:41 PM »
Ok....will post here.. maybe someone can help.
1st---I don't need help with the hardware..just the code.
Arduino Uno with AS3935 Lightning Detector. Here is the board/code I'm using.
http://www.playingwithfusion.com/productview.php?pdid=22
The code is at bottom of page.
I "think" its working via the serial monitor window.
Now...what I need is to alter the code so that when it detects lightning at greater than 12Km it will set
pin 7 high for 5sec..
or
When it is LESS THAN 12Km it will set pin 7 high for 5sec AND set pin 8 high for 10min.
What I am trying to do is:
Lightning greater than 12Km...it turns on a light for 5sec
Less than 12Km it turns on that same light for 5sec and disconnects my antenna for 10min.
Like I said...I can handle the wiring/hardware...but I don't know crap about coding!!... HELP---Anyone?!?!
Trip - KT4WO
kt4wo67@gmail.com
« Last Edit: February 04, 2015, 01:21:23 PM by KT4WO » Logged
KT4WO
« Reply #2 on: February 04, 2015, 01:19:54 PM »
Ohhhh and also.... both the 5sec and 10min timers would need to reset if it detected another strike before
either timer ran out.
Trip - KT4WO
AE4RV
« Reply #3 on: February 04, 2015, 06:07:33 PM »
Reddit has a group for everything.
http://www.reddit.com//r/arduino
KT4WO
« Reply #4 on: February 05, 2015, 05:42:22 AM »
Thats what I was looking for ..tnx
N8CBX
« Reply #5 on: February 09, 2015, 11:48:19 AM »
If you don't know how to do it, start reading:
Start with this free book
http://playground.arduino.cc/uploads/Main/arduino_notebook_v1-1.pdf
And then buy Brian Evens book, Beginning Arduino Programming
Also, keep this open in your browser, and refer to it while understanding the syntax.
http://arduino.cc/en/reference/homePage
Look at their simple example programs and learn from them
http://arduino.cc/en/Tutorial/HomePage
Then for interfacing with more complicated devices, you need the code libraries
http://arduino.cc/en/Reference/Libraries
Personally, I would stay out of the forums, unless there is something specific you are looking for. I find them mostly a waste of time. The best benefit is reading the books and the example programs.
The lighting board looks pretty neat, good luck,
Jan N8CBX
« Last Edit: February 09, 2015, 11:50:51 AM by N8CBX » Logged
Dayton Ohio - The Birthplace of Aviation
KD0REQ
« Reply #6 on: February 10, 2015, 03:26:04 PM »
there is a QnA group at arduino.cc as well if you poke about the site a bit.
N4CR
« Reply #7 on: February 10, 2015, 06:24:19 PM »
Hey, I like playing with Arduinos as much as the next guy, but how are you planning on disconnecting your antenna? A relay?
You do realize that the lightning just jumped several thousand feet right? That .05" between the relay contacts isn't much of an obstacle.
I mean, it's a fun project and all, but seriously... use a lightning arrestor. Hook the output to a beeper so you know when lightning is close but still distant. If it's close you'll know it.
« Last Edit: February 10, 2015, 06:29:06 PM by N4CR » Logged
73 de N4CR, Phil
Never believe an atom. They make up everything.
KT4WO
« Reply #8 on: February 13, 2015, 06:16:15 PM »
RE"You do realize that the lightning just jumped several thousand feet right?"
1,000s of feet??.....WOW...didn't know that.
I just sold my CB last week and got my 1st amateur radio, so I'm still
learning all this stuff. I did get my rubber duck mounted to my hardhat last night, just
need to install the ground wire now.
Thanks for answering my original question.
N8CBX had the best advise.
"I would stay out of the forums, unless there is something specific you are looking for. I find them mostly a waste of time."
KT4WO
KT4WO
« Reply #9 on: February 13, 2015, 06:30:28 PM »
RE: N8CBX
Tnx for the reply...I have bought 3 books already..and I'm learning SLOWLY.
I understand I need to poll  the distance and am thinking it will be a
"IF" and "ELSE" routine . Then the "Blink without Delay" to pull pins high...so the program
keeps running....  The last time I wrote any code was 35 years ago in BASIC
10 Print "Hello"
20 GOTO 10
That's what I know about coding! ..ha
And I will have to learn it..don't think this will be a copy and paste deal.
Back to Kindle and more books. Tnx again.
KT4WO
KA8VIT
« Reply #10 on: June 17, 2015, 06:11:51 AM »
Try the Arduino Forums...   http://forum.arduino.cc/
73 - Bill KA8VIT
KT4WO
« Reply #11 on: June 20, 2015, 08:21:40 AM »
Tnx Bill,,,
I joined it awhile back.
The project is on hold till next winter....ya know...summer is busy, busy.
The detector is working....but I have found(via datasheet) that at best...only
detects 40%, and thats VERY close-in. over ~10 miles and its much lower.
Should have read the datasheet 1st,,,,would not have spent the money/time.
Tnx
KT4WO
W8TEE
« Reply #12 on: May 17, 2016, 05:13:54 AM »
There's a new users' group for hams:
https://groups.yahoo.com/neo/groups/SoftwareControlledHamRadio/conversations/messages/1
If you're interested, contact me via my email on QRZ.
Jack Purdum, W8TEE
