Author Topic: stolen gear from K6IJ  (Read 7775 times)
K6IJ
« on: June 19, 2015, 06:39:12 PM »
In the morning hours of June 18 the following electronic and hand tools were stolen from my home.   The list may grow!
Up-dated list Friday, 26 July 2015
2 each  Bird 43 watt meter with three elements in each meter, plus two leather cases one Charcoal and one tan.  Tan unit had other fillings and ISO-tee in the top lid.
1 each RF systems 8100 meter, three elements in black plastic case
16, Bird electronics elements in various power levels from 5 watts to 2.5 KW in a strong black plastic case with my name and old call either W6YM or KH7Y
1 each Gateway laptop computer, with external wi-fi USB and a K-USB cw keying unit used with the N1MM logging system
1 each Hickok 6000A in as new condition S/N 391-04124 with aftermarket manuals
2 each new video monitors about 17 inch made by Element in new boxes
1 each new Drimil SAW MAX in it original box with many new blades
HP-Compaq  computer with professional XP, only one ham program installed N1MM/Plus, which has my name, call and address.  also external wifi USB Hs 5 com ports
1 each Cannon G3IS camera with SD card installed and pictures of my shack in Hawaii others
1 each Nikon l-13 mini 16pixel camera including the original box
Many  thumb drives with QSO data in ADI format for KH7Y and W6YM, NH6P and many pictures that cannot be replaced
1 each Mikita Rotor hammer, Drill 1/2 inch chuck in a green steel box new cost over $600
1 Each MFJ 269C antenna analyzer in a black carry case, with extra coax adapters and wall wart
2 each Heil PRO headsets in original packing, rebuilt by Heil and not used
1 each Eagle return bridge, RLB-150x3d
1 each Audio Technica high end noise cancelling headset plus two extra sets of cables
4 each  Eimac 3CPX-800s power tubes used, tested and good in packing and a priority mail large box
1 eacg MFJ packet, universal modem in original box cannot think of the number
1 each Heil PR-40 in rose wood case
1 each soft carrying case for the HP 8921A service monitor
1 each WX0B stack match
1 each Ameritron remote antenna switch RCS-8V
1 each Marage peak reading watt meter MP-2 older brown outside case, connectors change to N type
1 each Signal link unit set up for Icom, with cable for IC-275H
many Tektronics 7000 modules including 7CT1N,7a13,7a18,7b53,7b85, 7a26
25 each 6146W plus a few 6146A and 6146b in large shoe box
25 each 6146W, 6146A and 6146B made by General electric/Sylvania in a large shoe box.
1 each Motorola SINAD meter gray in color
1.  HeathKit SB-104A in large box with complete manuals have service stickers from RTO repair service, also extender boards.
!. New  screwdriver antenna new purchased from Don Johnson before his death, has brown insulator, very different from others with 56inch whip
3  large packages of plastic tie wraps, one package was clear with 1000 4 inch ties, along with invoice from Tanner electronics in Dallas purchased last week
3 each Motorola MAX-TRC G300 FM transceivers with programming cable
1 each high end VOM 20,000 ohms per volt in gray plastic case
1 each Velleman portable digital scope in black plastic case
1 each Drimil hand held took with attachments in gray plastic box
1 each large Arrow staple gun uses 3/8 inch staples
11 each  Snap-ON screwdrivers various types and sizes
1 each Snap-on set of small picks with pink handles
2 Drake 4B receivers in excellent working condition
1 Drake 4A receiver also in excellent condition this one and others above packed in large box
1 Drake TR-7A loaded with all options and filters, noise blanker
1 each BaoFeng dual band hand held fm transceiver (they left the charger)
!  each Ryobi 3/8 inch 12 VDC cordless drill, (took wrong charger)
1 Each Vibroplex "original" cw key gray base and chrome metal (purchase new in 1957) much history as a novice, Radioman in the U.S. Navy, she will be missed.
 Items may be sold at a swap meets, Eham, QTH.COM, QRZ, Craigslist or Ebay.   Any info contact Amador Sheriff case 15060924  phone 209-223-6411
« Last Edit: June 26, 2015, 08:29:39 AM by K6IJ » Logged
