Author Topic: FT-450 Digital Voice Recorder  (Read 7499 times)
KJ6MSG
« on: September 29, 2012, 08:35:51 PM »
I've had my FT-450D for about a year now and still love it. One thing I don't understand though is the Digital Voice Recorder. The Voice Memories make total sense (record a repetitive transmission and transmit at the push of a button)... but the Digital Voice Recorder doesn't transmit, it just plays over your speaker. Anyone find a purpose for this?
KJ6MSG
@kj6msg
K2OWK
« Reply #1 on: September 29, 2012, 10:31:38 PM »
I used it when I changed microphones (D-104 amplified base) to set the equalizer and to set the audio level for clean clear audio before I transmitted. This is a good monitor for audio in/out from the transceiver.
73s
K2OWK
KJ6MSG
« Reply #2 on: September 30, 2012, 10:27:56 AM »
Did not think of that... Thanks for the tip!
KJ6MSG
@kj6msg
W5TTW
« Reply #3 on: October 01, 2012, 05:04:13 PM »
I love my 450 as well and that feature can be confusing.  There's a difference between the Voice Monitor and Voice Memory.  You need to go into the function menu and assign the Voice Memory to the Voice CS button via the PNL-CS option.  Select VMITX to transmit the recording.  If you don't do that, you will only have the Monitor feature available when you push the button.
« Last Edit: October 01, 2012, 05:11:21 PM by W5TTW » Logged
K7AZJ
« Reply #4 on: January 22, 2016, 12:03:53 PM »
ok. I'm really not going to be able to test this for a while.
But here is what I did. And I need confirmatation from someone who has REALLY done this, and know it works.
1. Got into the Menu (by pressing the F button for one second)
2. Rotate DSP dial to PNL-C.S, and pushed the DSP button
3. Rotate to VM1REC, pressed the DSP button
4. Pressed F button for one second.
5. Pressed C.S/VOICE button once
6. The status said VM1REC and counted down from 3 to 0
7. Then status was replaced with VM1REC and counted down from 10. At which point, I pressed PTT and recorded a message, then I let go of PTT.
At this point I ASSUMED that what I said into the MIC was recorded into Memory 1.
8. I changed to PNL-C.S. to VM1MON
9. I pressed the C.S/VOICE button and I get Nada (Nothing)
Isn't VM1MON supposed to play the recording that I made?
If so, apparently I didn't record anything.
So what did I not do right?
Jerry
