Author Topic: RIGBLASTER PLUG AND PLAY  (Read 3189 times)
XE2VBG
« on: December 02, 2015, 10:46:47 AM »
Hi Guys:
I got my hands on a Rigblaster Plug and play Interface, I have hooked to Echolink tried out ant it works just fine, with mi FT 100...
Thats the radio I use on my car.... so I want to hooked up  a Yaesu 2400H that's laying around .... I can't seem to find reference on how to make this  work... I have read that it is just not compatible.  Is this so?  it must be a way to connect the mic to the data cable on Rigblaster?? Right???  Sad
Thanks for the help.
« Reply #1 on: December 02, 2015, 01:58:57 PM »
I have a PnP and have used it for many years.  You need a TNC for 2400
XE2VBG
« Reply #2 on: December 04, 2015, 09:27:09 AM »
Wow, thanks lot, I'll do that and let you know how it went..
XE2VBG  , 73!!
XE2VBG
« Reply #3 on: December 04, 2015, 09:54:24 AM »
BTW is there any place to find the diagrams to make the cable my self??
NA4IT
« Reply #4 on: December 04, 2015, 10:26:38 AM »
You can find the mic diagram at http://www.qsl.net/g4wpw/date.html#yaesu. The RX audio will come from the speaker jack.
There is no reason you can't use the Rigblaster with the proper connections.
XE2VBG
« Reply #5 on: December 04, 2015, 10:28:21 AM »
Thanks again, will let know how goes..
« Reply #6 on: December 04, 2015, 03:58:58 PM »
If you read rigs manual is says otherwise. Packet is only mode you can really use.
XE2VBG
« Reply #7 on: December 06, 2015, 09:58:56 AM »
The RigBlaster Plug and Play has 3 indicators: Power, CW and PTT.
PTT lights when echolink sends out an audio signal but I canĀ“t get the audio from the radio  to echolink. !!!
